M1.7 – what is the history behind it?
Home Forums Materials M1.7 – what is the history behind it?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #211628
    Another JohnS
      @anotherjohns
      I have a friend looking for a M1.7 tap – which I don't have.
      But, it brings up a question I have had for a long while – what is the history of M1.7, as opposed to M1.6 (ISO and DIN standards). The local shop can order in M1.7 screws of certain lenths/materials, and M1.6 in other lengths/materials.
      I put it down to old stock – probably not a lot of metric users, as I'm in the 2% or less of the local ME club that chooses to build in metric.
      Any background? Merci – John.
      Another JohnS
        @anotherjohns
        #211640
        jason udall
          @jasonudall57142
          Well in production we once supplied to customer order parts tapped M 1.6.. to mate with M 1.8 male
          This was for a purpose of their own.
          ( not explained to us)…
          At the time I was lead to believe the pitch was simular enough that the m1.6 m1.7 m1.8 was almost more a “fit” issue?rather than size.
          #211643
          Muzzer
            @muzzer
            Could M1.7 also be known as 10BA??
            #211662
            Another JohnS
              @anotherjohns
              Checking further, the pitch is the same between M1.6 and M1.7 (At least according to 1 reference)
              Murray – interesting thought about metricizing 10BA as M1.7 – pitch is incredibly close, (0.351 vs 0.350). Different thread form, but maybe, so what??
              Jason – you are right – all the same pitch.
              Emailed my friend, who is a BA-aholic, and suggested he try 10BA and see what happens. (It's for an Aster locomotive kit out of Japan)
              John.
              #211663
              jim’
                @jim11037
                all you need to know about metric threads
                David Jupp
                  @davidjupp51506
                  The BA option sounds sensible. In the parts manual for an old Olympus camera, all screws were described in mm – study revealed they were all BA equivalents.
                  #211682
                    Why M1.7?
                    The most useful series of fixings (or anything needed in a wide range of sizes) go up in steps of similar size, so that whatever your 'ideal' size is there is always a standard (or 'preferred&#39 size nearby.
                    The best example is resistors, which go up in odd values, or at least they seem odd until you realise that the values are spaced so that they go up in steps more or less regular steps of 1.5 times the previous value (at 20% tolerance). For higher tolerances they go up in smaller steps, always chosen so that there aren't any gaps between the tolerance bands.. This minimises the number of values they need to make, means there are no 'rejects', and simplifies the design process.
                    The steps can be any size. For BA fixings the step is such that as you go down the series each size is 0.9 times the previous one – quite close together which is why just the even sizes are more commonly used.
                    Other examples are things like A-series paper where A4 is twice the area of A5.
                    For ISO metric things there are the R5, R10, R20, R40 and R80 series which break down each 'decade' (from 1-10 or 100-1000 for example) into steps of 10, 20, 40 or 80 roughly even-proportioned steps.
                    Engineering ignores these steps so most metric screws you come across are rounded to the figures: M1, M1.5, M2, M3, M4, M6, M8, M10.
                    The final answer to your question is that M1.7 is the most useful size between 1.5 and M2.
                    Ajohnw
                      @ajohnw51620
                      There is a site that lists metric threads that might be of interest. Topsy springs to mind.
                      Bazyle
                        @bazyle
                        Since you said it was for an Aster loco, Japanese made but I think designed in Switzerland, it will depend on the designer and whether he is a hands-on practical man or an academic CAD jockey. Wanting to meet scale (of a sort) the designer will have found that M1.7 is the required size and exists in the tables. Being Swiss every possible small screw will be available locally so he just specifies it no problem. A hands on man would have known what was more commonly available and adjusted. The Far East like to follow instructions so will not suggest an alternative and just build to print at slightly extra cost.
                        How did the friend determine it was 1.7mm. Either he measured the diameter and quoted that not actually differentiating it as metric or BA, or he has a parts list, (quite likely as many are sold as kits) that specifically declares it as M1.7 therefore not BA.
                        Edited By Bazyle on 12/11/2015 13:43:52
                        #211755
                        KWIL
                          @kwil
                          There are some strange metric thread uses. Japan uses M2.6.
                          Lost a locking screw on a S/S mechanical vernier, too quickly measured it as M2.5, made one did not fit!!sad
                          Measured it more carefully, made one as M2.6, worked a treatsmiley
                          No logic as to why it was M2.6
                          #211760
                          Ajohnw
                            @ajohnw51620
                            Posted by KWIL on 12/11/2015 15:49:01:
                            If you look at the ISO extended metric threads here you will see there is nothing odd about M2.6 at all
                            On the other hand they have been rationalised and I believe this is one is more up to date unless JIS has dropped some of theirs.
                            It pays to check dia and pitch on Japanese microscope. German too.
                            Clive Hartland
                              @clivehartland94829
                              Of interest, while working for a very well known Swiss Company they did in mid stride opt to use the new Din Norm on threads so we ended up with several different threads used on instruments and it was particularly annoying to find small threads on items that you had used say 1.7 suddenly were 1.6.
                              We also used a lot of non standard threads as we needed very fine movement for adjustment purpose on bubbles etc. We also found that the taps and dies for these threads extraordinarily expensive. A 5 start thread for eyepices at £280. Some large diameter very fine threads I made myself as we would not have got the purchase through the finance dept.
                              #211766
                              ega
                                @ega
                                John W 1:
                                "There is a site that lists metric threads that might be of interest."
                                Thanks for reminding me of this useful site – it feels odd that one goes to the US for such a comprehensive list.
                                #211773
                                KWIL
                                  @kwil
                                  John,
                                  I was well aware that it was an ISO thread, just odd they chose it!
                                Home Forums Materials Topics
