M G Electrics (Colchester) suds pump wiring.
Home Forums Electronics in the Workshop M G Electrics (Colchester) suds pump wiring.
  • #32150
    Jim Beagley
      @jimbeagley46363
      Jim Beagley
        @jimbeagley46363
        I’ve recently acquired a suds pump which I want to fit.
        The back of the motor says
        380/220
        440/250
        its written like that but it’s one slash.
        It also says 3phase and 0.122/.22A
        Now although it says 3phase, looking at those voltages, I’m thinking it’s both 3P or 1P, star or delta. Does that make sense?
        It has terminals numbered 1-4 and 5 wires from the motor itself – 2 distinct windings perhaps?
        It’s currently wired up with an external capacitor, and a 13A plug and it runs ok but the wiring is old. When I opened up the motor case to take a look it’s clear that the cap wires have got pretty hot in the past.
        So, shall I just repair the wiring and carry on using single phase with a potential issue, or convert it to 3 phase which means quite a lot of hassle in the then required 3P connection and switch?
        anyone got any thoughts and even better, a terminal diagram of this motor?
        Cheers
        Jim
        #506552
        Stuart Bridger
          @stuartbridger82290
          Hi Jim,
          That's exactly how my suds pump is wired. Motor run cap to give the third phase. Very easy way to run a low powered 3 phase motor off a single phase supply. No need to change. I would tidy up and leave as is. I think there is a terminal diagram under the cover of mine, but I'm not too enthused to poke about down the back of the lathe to dig it out.
          #506657
          DC31k
            @dc31k
            It is a good motor: it will run happily on high voltage 3-phase, low voltage 3-phase or single phase (with capacitor).
            Are you quite sure on the five wires? It should be six, one for each end of the three motor coils. When I took mine apart with a view to rewinding it, I do not remember the star point being buried. This was an old one with the switch on the top of it.
            Most modern motors you see have six-way terminal blocks as standard, with brass bus-bars, to allow star or delta connection.
            I think the only thing different in this motor is the terminal block itself; it only has four connections, for star operation. If you change it for a six terminal block, you will have all options open to you.
