M-DRO help?
M-DRO help?
Home Forums Workshop Tools and Tooling M-DRO help?
Viewing 23 posts - 1 through 23 (of 23 total)
  • #662117
    Bo’sun
      @bosun58570
      Morning all,
      Here's hoping someone can help. I've contacted M-DRO (Allendale) but won't get an answer until at least Monday, and I would realy like to press on.
      I've had the DRO for a year or two and it's been fine up until now.
      The "centre find" function on my MDC700 isn't doing as I understand it should.
      Following the user manual, instead of displaying 0.000 as the centre of the part, it displays the centre as what appears to be, half of the distance between the two edge finder centre locations. I hope that makes sense?
      I was wondering if I need to reset something?
      Bo’sun
        @bosun58570
        MDC700 DRO “centre find” function
        #662120
        Tony Pratt 1
          @tonypratt1
          My DRO reads zero when I am physically in the middle of the part. PS not the same make as yours
          Tony
          Edited By Tony Pratt 1 on 30/09/2023 10:17:52
          #662124
          Nealeb
            @nealeb
            Can you explain how you are using it? I cannot find an online manual for this model.
            I have an Easson display (also from M-dro) where the sequence is:
            – Pick up one edge and zero axis readout
            – pick up opposite edge and press 1/2 button.
            That halves the value in the readout, which is the equivalent of putting zero at the mid-point of the work and works whether you initially zero at the + or – side of the work.
            Is yours similar or does it work differently?
            #662126
            Tony Pratt 1
              @tonypratt1
              Nealeb, yes that is what I do, so what is your problem as your DRO will read zero when your mill spindle is over the part centre line? My DRO is a Knuth make.
              Tony
              Edited By Tony Pratt 1 on 30/09/2023 10:33:37
              #662130
              Bo’sun
                @bosun58570
                Hi Nealeb,
                Find one edge and press the zero key for the appropriate axis (Y in this case).
                Find the opposite edge and press axis selection key.
                Press the 1/2 function key.
                Display would previously have shown the centre of the part to be 0.000 (as it should), but now shows it as half the centre distance between the two edge finder positions.
                Hope that's clear.
                #662133
                Roderick Jenkins
                  @roderickjenkins93242
                  I think there's a button press missed out in the above sequence.
                  So, in Y:
                  Find one edge, press Yo
                  Find other edge, press 1/2 then Y (not Yo)
                  Move back to zero, this should be the centre.
                  Hope this helps,
                  Rod
                  Edited By Roderick Jenkins on 30/09/2023 11:05:47
                  #662134
                  Clive Foster
                    @clivefoster55965
                    Bo'sun
                    If you zero at the first edge, find the second edge the display should read the distance between the edges (plus the centre finder probe diameter).
                    If you them press the 1/2 function key the display reading should halve.
                    Winding back to zero should place the quill above the centre position.
                    Questions :-
                    1) Does the display reading halve when you press them 1/2 key?
                    2) Does the display count down to zero when you move back towards the middle or freeze on the 1/2 value?
                    If the reading doesn't halve when you press the 1/2 key odds are the key isn't working properly. Contact issue under the membrane.
                    If If the reading freezes and doesn't count down you may have entered a lock mode.
                    My Sino set up has a lock mode if I read the book correctly. Something I make sure to stay the hell away from as the potential for confusion is obvious. That said I can see various uses for it if you exploit the other memories. Transfer of dimensions to replicate feature in other places for example.
                    #662136
                    Nealeb
                      @nealeb
                      FWIW, my initial question was aimed at the OP – my own DRO works perfectly! However, as pointed out by others, I did forget the step of specifying the axis to halve – otherwise how does the DRO know which axis?
                      This does make me think, though, that the effect described in the original question could happen if you hit the "X0" button when you are selecting the axis rather than "X", say.
                      It is, perhaps, slightly misleading to call the "1/2" button the "centre finder". While that's what everyone uses it for, actually all it does is halve the value in the display, hence its name on the front panel. Really useful, all the same!
                      #662138
                      Bo’sun
                        @bosun58570
                        Clive,
                        I'll check this afternoon.
                        #662139
                        duncan webster 1
                          @duncanwebster1
                          Posted by Bo'sun on 30/09/2023 10:47:48:
                          Hi Nealeb,
                          Hope that's clear.
                          You've got the key press order reversed
                          Find one edge, say Y
                          Press Y0
                          Find the other edge
                          Press 1/2 followed by Y (not Y0)
                          #662141
                          Bo’sun
                            @bosun58570
                            Thanks duncan,
                            I'll try that, but it's not the sequence shown in the M-DRO manual that's worked previously.
                            #662147
                            Steviegtr
                              @steviegtr
                              Posted by Bo'sun on 30/09/2023 11:52:52:
                              Thanks duncan,
                              Bo'sun I have the Mdro. I have just done a video & i show the edge finding on the dro. Its near the begining so you won't have to skip far. Hope it helps.
                              Steve.
                              #662150
                              Bo’sun
                                @bosun58570
                                Clive,
                                In answer to your questions:
                                1) The reading does not halve when the 1/2 function key is pressed. It stays on the Y (axis location) reading.
                                2) The reading does not freeze, but counts until the zero position is half of the two edge finder locations. ie; If the two edge finder locations are 24mm apart, zero (centre location) appears to be 12mm.
                                Duncan,
                                Changing the sequence does not work.
                                #662153
                                Bo’sun
                                  @bosun58570
                                  Thanks Steve,
                                  That's exactly what I'm doing, but pressing the Y (axis location) key doesn't display "0" as shown in your video. I fear something may be amiss with the MDC700 unit. I'll see what M-DRO have to say next week.
                                  #662175
                                  Clive Foster
                                    @clivefoster55965
                                    Bo'sun
                                    Pretty sure that the 1/2 key isn't working.
                                    #662241
                                    Pete
                                      @pete41194
                                      That 1/2 function is just a faster and nice to have (when it's working) item. But if the dro is still accurately measuring linear distances. You can still do exactly the same without that 1/2 function. Let's use the Y axis for example, accurately measure your part width, divide that in half. Edge find the part, move over half the distance of your edge finders tip. That puts your spindle center line directly over the part edge. Zero the dro's Y axis, now move over that half distance of the part you previously calculated for it's width. But I'd stress that accurately measure part. Caliper measurements for your part width can't and won't give you the same accuracy as the dro and that half function will. So micrometer measurements would be the better way if your part centering does require that level of accuracy. Analog hand wheel dials obviously haven't any half function either, so you just use the dro in much the same way as you would with those. Yes it will take just a bit longer, and there's a few other ways to do this, but will still allow you to do what you want until your dro issues can be resolved.
                                      #662283
                                      Bo’sun
                                        @bosun58570
                                        Thank you Pete,
                                        A good suggestion to get the project moving. I'll give it my best shot after lunch.
                                        #662290
                                        Metalhacker
                                          @metalhacker
                                          On my M-DRO unit you have to use the ENT key after the 1/2 function. That then gives you the 0 point at the centre of the 2 readings.
                                          Any help?
                                          Andries
                                          #662318
                                          Bo’sun
                                            @bosun58570
                                            Thank you Andries,
                                            I'll give it a try, but it's not what the M-DRO guidelines tell you to do. The problem is, all worked fine previously, but now it's just stopped working. Let's see what Allendale (M-DRO) have to say next week. Fortunately it's still under warranty (just).
                                            #662322
                                            Steviegtr
                                              @steviegtr
                                              Certainly seems like a fault somewhere.Hope you get results from supplier. They say they are very good & at least in the UK.
                                              Steve.
                                              #662329
                                              Tony Pratt 1
                                                @tonypratt1
                                                Posted by Bo'sun on 01/10/2023 13:32:29:
                                                Thank you Andries,
                                                Hi Bo'sun, In the UK a suppliers warranty period is irrelevant, UK consumer law states an item should be of reasonable quality and last a reasonable time, just a heads up but I think Allendale are a decent company.
                                                Tony
                                                #662477
                                                Bo’sun
                                                  @bosun58570
                                                  Good afternoon all,
                                                  Well, would you Adam & Eve it. Over the weekend I got my partner to give me her thoughts (she's a better button pusher than me). Low and behold, doing nothing different, the DRO burst into life, and "touch wood" has been fine ever since.
                                                  This afternoon a gentleman from M-DRO (Allendale) called in response to my enquiry, and although there wasn't much he could say, he did suggest the cause may be due to the unit having been unused for some time. Which is the case. Apparently, unlike some units that use membrane switches, the MDC700 uses mechanical switches, so who knows?
                                                  Anyway, thanks for all the comments and suggestions.
