1) Is there a photo availabLe of the cOmpleted engine showing the steambox and valve crank end?
2) The Drawing of the cylinder shows a passage Going from thE steam chest down to the Base of the cylindeR. While it is Obvious steam has to get into the cylinder, what is not obvious is size and location in the cylinder wall. Any information on this would be gratefully appreciated.
3) A quick hint at the dimensions of the base would also make this model easier to construct.
