Ludwig-Hunger valve seat cutter
Home Forums Related Hobbies including Vehicle Restoration Ludwig-Hunger valve seat cutter
  • #566774
    Mick Bailey
      @mickbailey28509
      For anyone who isn't familiar with this type of cutter it uses a tungsten-carbide single point tool that machines out the seat at the appropriate angle. It behaves like a lathe tool – in reality creating a spiral cut. It's remarkably versatile in that DIY cutters can easily be made. Last year I rebuilt a Honda CB450 head and made up the required tool by brazing a tip to a piece of tool steel.
      Unlike most cutters that only use a pilot to loctate a cutter head in the valve guide, this uses an additional outboard support clamped to the head for rigidity and precision. Any number of seat angles can be cut – I used a 3-angle cut on the Honda.
      The question I have is that I would like a PDF copy of the original instruction manual that came with the set. Mine is missing and I know there are many setups illustrated for different applications. It's perhaps an early 60s Mk1 set in a wooden case.
      Mick Bailey
        @mickbailey28509
        #566796
        steamdave
          @steamdave
          I had never heard of a Ludwig Hunger valve seat cutter before, so did a quick search and I found out the company is still in business.
          https://www.ludwig-hunger.de/index.php/eng/Products/Automotive/Counterboring-valve-seat-ring-bores
          Maybe worth contacting them.
          The Emerald Isle
          #566806
          Mick Bailey
            @mickbailey28509
            Thanks Dave. I contacted them a while back and they sent me a link to the latest version, which I already had. This doesn't have the contemporary vehicle specific instructions – mainly for aircooled VW and other applications. Also, there are different accessories and fixtures that are no longer shown in the newer instructions (mainly because its all obsolete).
            I also posted on the Samba forum and had a reply from an owner who had an original manual and he said he'd scan and email it but never did. His account is no longer active. I can use the cutter set without issue, but would like to get the manual to go with it anyhow.
            #566864
            Oily Rag
              @oilyrag
              Mike,
              I have the remnants of a 'partial' set of Hunger seat cutting tools and there may be an instruction manual buried in the box with those remnants. I had it a long time ago and used it regularly, then someone borrowed it and when it came back I foolishly didn't check the contents! It went with a Hunger valve lathe that was a beautiful little thing, single point valve seat cutting at any angle desired.
              I'll dig it out the shed and look as soon as I get the chance.
              Martin
              #566883
              Mick Bailey
                @mickbailey28509
                That would be great. I'd also be interested in the remnants if you wanted to sell what you have as my own set is incomplete.
                #566912
                Oily Rag
                  @oilyrag
                  Mick,
                  I'll dig it out and PM you as to what is there.
                  Martin
