What do you call stiff, if its so stiff you think its stressing the connection to the table then something is clearly wrong and I would suspect the mounting of the unit. What did it feel like before it was mounted..? With the reader head fixing released the connecting bracket should be just touching the mounting position there should be no gap or over close which would put pressure on the head when fixed.
If your mounting is good and the unit is as stiff as you suggest then it's obviously faulty.
Do NOT lubricate the rail it needs to be clean and dry, ARC say in their spec that the units need protection from swarf and coolant etc. I made up guards/covers for mine from 25 x 25 x 1.5 alu angle, simple to do and works well.
Edited By Ron Laden on 18/09/2021 05:23:15
Edited By Ron Laden on 18/09/2021 05:44:32
