LPG Gas jet sizing
LPG Gas jet sizing
Home Forums Locomotives LPG Gas jet sizing
  • #213013
    michael howarth 1
      @michaelhowarth1
      My Gauge 1 gas fired loco was running well until the gas jet, marked "10" became blocked again and again. I replaced it with a new gas jet marked "8" from my usual supplier, expecting perhaps a small loss in heat output. What I did get was a gas overload – great difficulty in lighting the ceramic burner and gas burning at the chimney even when the burner was alight. On inspecting number "8" it was clear that the orifice of the jet was much larger than the orifice of the number "10" jet. In general jet orifice sizes increase with the jet number but my limited research has discovered that different manufacturers eg blowlamp, camping stuff, LPG fires etc apparently use different jetting numbers. Does anyone know of a jet comparison/ cross reference/application type of chart that might throw some light onto this murky area?
      Mick
      michael howarth 1
        @michaelhowarth1
        #213048
        Gordon W
          @gordonw
          Sorry I can't help, but I do know that jet sizes refer to the quantity of fluid that can flow under given conditions. So I guess that the conditions are different for the makers ?
          #213059
          Keith Long
            @keithlong89920
            Mick it might be worth asking on the 16mm narrow gauge modelling Yahoo group. I know there has been discussion of gas jet sizes and alternatives on there earlier this year. Keith
            #213104
            michael howarth 1
              @michaelhowarth1
              Thanks gents. I will have a look at the 16mm site.
              Mick
              #213132
              michael howarth 1
                @michaelhowarth1
                I have had a look at the 16mm site and it is my impression that the correspondents are similarly searching in the dark. One post mentioned correct burner/jet design as being desirable if not essential but it went no further on detail. I feel that I now need to go back to basics and tackle this burner/jet design thing. Where to start? That is the question.
                Mick
                #213137
                maurice bennie
                  @mauricebennie99556
                  Carburetter jets ? There is the SU manual .Burlen fuel systems . Worth a try
                  Maurice.
                  #561613
                  Fred Graham 1
                    @fredgraham1
                    Hi Folks,
                    Although I cannot, personally, vouch for these sizes they came from a good source, Mike the former MaccSteam boiler maker now retired
                    The sizes are Number 3 has 0.15 mm jet bore
                    Number 5 has 0..2mm jet bore
                    Number 8 has 0.25mm jet bore
                    Number10 has 0.277mm jet bore
                    Number 12 has 0.3mm jet bore
                    Number 16 has 0.35mm jet bore
                    I hope that will add some more to the general information source
                    All the best Fred Graham
                    #561614
                    Fred Graham 1
                      @fredgraham1
                      The first one should be 0.2mm not 0..2
                      Fred Graham
                      #561618
                      Fred Graham 1
                        @fredgraham1
                        Hi Folks,
                        Does anyone know who supplies jets for burners as most of the suppliers of boilers and burners do not seem to.
                        I found one the does called 'Maidstone Engineering Supplies' but there must be others. Someone mentioned a 'Usual supplier ' Who might that be?
                        All the best, Fred Graham
                        #561637
                        Harry Wilkes
                          @harrywilkes58467
                          May give Forest Classics a call link
                          https://www.forest-classics.co.uk/
                          No connection
                          H
                          #561682
                          Fred Graham 1
                            @fredgraham1
                            Hi Harry,
                            Thank you for the Link but they don't seem to sell Jets. I tried there 'search bar' and it came back as not recognised, so it look like another supplier not stocking them, which Is surprising.
                            I will contact them again and see f I can get a clear 'yes or no' response.
                            #561691
                            Roger Clark
                              @rogerclark
                              Posted by Fred Graham 1 on 07/09/2021 08:40:04:
                              Hi Harry,
                              Not sure how much exploring you did but if you had scrolled down to the bottom of the page you would have seen a link to the page you need – gas essentials and jets
                              Roger
                              #561701
                              Iain Pailing
                                @iainpailing54696
                                Hi Harry,
                                Try looking on the 16mm web site on the 'resources' pages. You could also try Anything Narrow Gauge, Chuffed to Bits, Roundhouse Engineering or possibly Garden Railway Specialists. If they cannot help they may be able to point you in the right direction. Might also be worth contacting Polly Models.
                                Hope this helps,
                                Iain
                                #561714
                                not done it yet
                                  @notdoneityet
                                  Seeking advice from the supplier(s), after accurately describing the problem experienced, would be my course of action.
                                  #561754
                                  Fred Graham 1
                                    @fredgraham1
                                    Hi folks,
                                    Thanks for comments and especially Roger, OOPs did not notice that link on Forrest Classics, What a plonker!
                                    Lost inside a paper bag and can't find the way out and poor explorer, to boot. Thanks again for keeping me right.
                                    They seem to have a good range and reasonably priced too!
                                    All the best, Fred
                                    #561764
                                    Speedy Builder5
                                      @speedybuilder5
                                      You can re-size a jet if it is made of brass.
                                      Buy yourself a set of Swiss Broaches typical brands BERGEON No 1896 They are a bit pricey, but you may find some on various auction sites.
                                    Home Forums Locomotives Topics
