My understanding is that in an older manual-valve-only radiator system, then you should (or the installer should but probably never does) set up the system by opening all the manual valves fully, then adjust the lockshield valves in each room until eventually each room is taking an appropriate proportion of the circulating hot water. To adjust the system for the appropriate return pipe temperature, this presumably needs all the LS valves opening/closing in the correct proportions to adjust the total flow volume. The effect of closing the manual valve in, say, an unused bedroom will unbalance this setup but presumably not by too much to matter. Somewhere there is also a single room temperature thermostat which will respond to the temperature in that one room but will turn on or off the heating in all rooms. So far so good? However, this setup takes no account of things like solar heating, which will vary between rooms, time of day, as well as amount of sun. So the “balanced” room temperatures will be a bit of a compromise.
Now we move to the more current situation of mechanical TRVs on all radiators. This is the point where I start to wonder about the role of the LS valve. Whether fully or partially open, the room will (providing the LS valve allows enough hot water to pass) get to temperature and then the TRV will close (partially, I guess) to reduce the flow in that radiator. Assuming that we are heating the house from cold, then the LS valve will alter the rate at which a room heats up, but has little influence on the end-point temperature. So if the LS valves are open by different amounts, we can affect the rate at which rooms heat up, but not really have much effect on the temperature once stable. Again, I presume a single room thermostat – in a room with no TRV? – to shut down the boiler when the target temperature is reached, or else we could imagine the boiler and pump running with all TRVs shut under certain circumstances. Not desirable? But we can cope better with solar input, etc. Should we fiddle about with the LS valves to adjust total flow to get the desired return temperature, or is this a waste of time as it will vary with the total radiator demand as controlled by the TRVs?
When I moved to my current house, I was surprised to find that there were TRVs on all radiators, a time switch, but no room temperature thermostat. I have no idea how that was supposed to work but presumably someone felt that there would be at least one radiator open at any time. I fitted a room temp thermostat fairly soon after I moved in.
The most modern form of TRV is a wireless valve which does not have any proportional opening – it’s fully open or fully shut. I have now fitted these in my own house with a central controller that can provide what amounts to room-by-room temperature and time programmes. So, main bedroom and bathroom come on first, followed by kitchen a little later, followed by whatever. Bedroom goes off and stays off until bedtime. By “off”, I mean that the temperature is allowed to fall to a predetermined setting. This system copes with solar input, etc, as all control is room-by-room. The documentation also tells me that the controls having a “learning” feature that allows them to set “on” times to account for how quickly a room heats up. And, of course, there are the expected “control it all over the internet” features to allow me to regulate things from a distance.
So how do you control return temperature, use LS valves, and so on, to get the best out of a modulating condensing boiler in this situation? Not having such a boiler it’s a bit academic at the moment but I know that my system can provide an interface box to make use of one.
All the above represents my best understanding of how things work but based somewhat on conjecture – I look forward to hearing from the experts!
