I have bought a new £26 optical rev counter and would like to check the accuracy of it at high rpm and how can it be checked in a home workshop.
It has been checked against various electric motor nameplate speeds and the readings are as followers, these motors are not under load.
Examples 2,800rpm motor, minimum optical reading 2,993rpm, nearly 200revs out.
My mechanical counter reads 2850rpm
On a quality 25,000-rpm motor minimum optical reading was 30,000 over 5,000 revs out.
An article that I read on speed testing of electric motors says a strobe should be used?
I require to check a speed range around 70,000 rpm the optical goes up to 99,000rpm.
A visual slow speed test was done on my lathe i.e. Slowest back gear was selected and a mark placed on the chuck backplate then rpm counted against a stopwatch for a minute.
The lathe speed plate says 50rpm, my stopwatch test gave just over 62rpm, the optical rev counter read 62.4rpm and a mechanical rev counter said 60rpm
My mechanical counter only goes to 20,000rpm.
At slow speeds the optical counter is reasonably accurate but when the revs go above about 2000rpm there are large discrepancies compared to the mechanical counter.
Any suggestions or are these lower priced optical rev counters unreliable at high speeds.
Another identical rev counter was supplied and it reads the same.
Windy
Edited By Windy on 22/02/2010 17:00:45
Edited By Windy on 22/02/2010 17:01:53
Edited By Windy on 22/02/2010 17:05:24
Edited By Windy on 22/02/2010 17:11:16
