Posted by Martin King 2 on 06/07/2017 17:16:47:
Ketan, many thanks, point taken! Quite a bit of work but will have a go. What is the 2RS/zz ? is that on the bearings? Are there different types of seals and shields please?
I guess that I was thinking that someone may have a project thaty might fit the bearings I have, a kind of cart before the horse deal!
I'll post some pics later anyway.
Cheers. Martin
Yes, 2RS means two rubber seals and zz means two metal shields.
Looking at the pictures, the bearings which are in their original packaging should be kept that way, without opening them. Just write down the bearing number as stated on the packaging – Brand – and qty.. There are some very good brands there in their original packaging. They do not loose value.
For the rest, it would be difficult to confirm the quality of the loose bearings. Still you can make a note of the bearing numbers marked on them. Most bearings are marked with bearing numbers which are in accordance with international bearing numbering systems, which in-turn translate into known sizes.
Ketan.
