Yep, £12.50 each
The outside dimension of the pattern is Ø34.1 and the height is 8.45 ( this allowed for some very slight machining )
The finished casting came out at Ø33.25 x 7.95.
The text on the pattern measured 2.3 tall by 0.5mm high, i think this is possibly the limit, any smaller and i think the process would struggle.
If i was to do these again, i would leave the text as is, but raise the outer and inner ring slightly so i could run this on a pierce of wet & dry but not touch the lettering.
but for now, as Jason suggests I think i will just give them a nib over as i quite like the cast look,
PS..
If anyone does know a chap called Abbott who has a son, and who is building a 1" minnie then pass them onto me, could do them some cheap(ish) hubs..![wink 2 wink 2](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
