Lost wax casting
Lost wax casting
Home Forums Workshop Techniques Lost wax casting
  • #150041
    Alex DU PRE 1
      @alexdupre1
      Hi all,
      The novelty of machining parts from billet is starting to wear off and I am looking to add home casting of aluminium to my repertoire of techniques, particularly lost wax casting. There does not seem to a lot on this topic in the forum so I was wondering if anyone has any experiences or advice that they would be willing to share. I'm thinking of going down the home-made gas fired furnace route.
      Alex
      Alex DU PRE 1
        @alexdupre1
        #150043
        Oompa Lumpa
          @oompalumpa34302
          I do a bit but use sand cores and oiled green sand. I find it extremely interesting and strangely theraputic. I hope to try bronze this summer. I use a home built propane furnace. Buy all my stuff from John Winters who advertise on here. Made some of my tools and ASDA are a good source of stainless utensils that can be adapted. The plunger I use for the degassing tablet for instance is a modified sink plughole strainer welded to a bit of stainless rod. You need to be creative, or have deep pockets.
          graham.
          #150046
          Michael Cox 1
            @michaelcox1
            Hi Alex,
            Do not dismiss lost foam casting. Patterns are easily made, no draft is required on parts and the process is very simple. Ideal for one off parts. There is much more info on my foundry pages see:
            http://mikesworkshop.weebly.com/foundry.html
            #150065
            Ady1
              @ady1
              Various ME issues have articles
              Searching for "lost wax" or "patternmaking" gets results
              #150080
              Davey J
                @daveyj
                Hi Alex, I have recently started making patterns for the "Gingery Shaper". Furnace will also be along Gingery lines – charcoal fired. I already have a gas cylinder cut and suitable fan sourced, off to local tip in morning to look for hoover type stainless tubes for air inlet. Recipe for foundry liner can be found here **LINK** cheers for now. David
                Link edited so it works as per Graham's post by JasonB
                Edited By JasonB on 18/04/2014 20:21:04
                #150121
                Peter Tucker
                  @petertucker86088
                  Hi Alex,
                  You should be able to get all your answers on this forum.
                  Best of luck.
                  Peter.
                  #150125
                  Oompa Lumpa
                    @oompalumpa34302
                    Davey, you missed the last "L" off, the link is here FURNACE
                    #150129
                    Alex DU PRE 1
                      @alexdupre1
                      All, many thanks for the interesting and helpful comments and links. Certainly no excuses not to get started now! I recently found a book entitled 'Lost-Wax Casting' by Wilburt Feinburg in the library, which is worth getting hold of. It's aimed at casting in third world countries so focuses on doing things with locally-sourced materials (mainly clay and animal manure!) but some good ideas for those of us who like to do things with minimal expense. In fact I subsequently found a PDF of this book on the internet, but I am reluctant to give the link as it is probably not a legitimate copy.
                      Best regards,
                      Alex.
                      #150178
                      HomeUse
                        @homeuse
                        Hi – This site is quite interesting for anyone interested in melting metals
                        Unfortunately there is not much about lost wax casting
                        http://www.backyardmetalcasting.com/index.html
                        #150248
                        Davey J
                          @daveyj
                          graham
                          Oops, thanks Graham – will try harder
                          David
