Posted by Bob Unitt 1 on 30/04/2023 18:36:10:
Posted by SillyOldDuffer on 30/04/2023 13:10:13:
It does fit in the space though! Headroom a small problem – it's 350mm less than my 2.3m ceiling, so I had to be little careful about lights and the up and over door.
How long is the draw-bar ? At my last home I had to cut a little hole in the ceiling of the workshop to insert or remove the draw-bar in my VM-B, fortunately there was about 1/2" clearance under the floorboard of the bedroom above.
Good point, though not on the WM18. This style of mill has the motor perched on top, so the drawbar has more headroom than on other machines. It's about 300mm long, and I could remove it with the head cranked fully up if I had to. As doing so would require me to stand on a box, I normally lower the head to a more comfortable height, where there's plenty of room.
The layout of the machine is good for smaller workshops, but it's not as rigid as the next size up and there's no knee. It's a decent compromise considering my space limitations.
