Looking into a collaborative build of a few units from an American set of plans.
Plans call for 4" x 3" and 3 1/2 " x 2 1/2" rectangular box sections of 1/4" wall thickness. Build video shows these telescoping inside each other after the projecting weld seam on the larger section has been removed.
I'm not totally surprised that imperial rectangular box can, apparently, no longer be obtained off the shelf. But I am surprised that there is no near equivalent pair of metric sizes around. Nearest I can find is 5 mm wall square box in 70, 80, 90 and 100 mm sizes.
Is this lack really the case or am I just looking in the wrong places. I'm going to need about 2.5 m of the large one and 2 of the small one. More if more folk come on board.
I can re-jig the design so the square tube works, it has to be metrificated anyway and I need to generate drawings for the laser of water jet cut parts, but rectangular box is a more appropriate shape for the job and style. The idea of welding up a non standard size from channel or angle doesn't appeal.
