Looking for a supplier of 20mm and 25mm hardened and ground shafting
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Looking for a supplier of 20mm and 25mm hardened and ground shafting
  • #15013
    John McNamara
      @johnmcnamara74883
      John McNamara
        @johnmcnamara74883
        Hi All
        I am in the middle of designing a small Desktop CNC machine and thinking of using round shaft in the design. If it works well I will publish the design. it needs to be the hardened and ground steel as used with linear bearings.
        Hopefully a local UK supplier to make it easier for constructors.
        Cost is an issue about 3 metres is needed per unit. (in 6 cuts so no worry with transport, maximum length is about 700mm) some 20mm and some 25mm
        Cheers
        John McNamara
        #121368
        Boiler Bri
          @boilerbri
          Hi John,
          Try, HTS in Huddersfield 01484 559995.
          No connection only a customer.
          #121376
          Douglas Johnston
            @douglasjohnston98463
            When I built a quorn grinder many years ago I tried to find hard chrome plated round bar but could not find a supplier willing to sell a small quantity. This may be easier to find these days and would have the advantage of being rust resistant.
            Doug
            #121383
            Gordon W
              @gordonw
              Hydraulic cylinders, as used on tractors etc. Scrap ones cheapest !, worth trying the specialist repairers.
              #121385
              maurice bennie
                @mauricebennie99556
                Hi John , Scrap photo printers have good steel shafts which the carriage runs on .I do no know if this is of any use ,being 8mm dia 400mm long (the pieces I have).
                Maurice
                #121386
                  Just put "Linear Shafting" into Google and you will get plenty of suppliers plus suitable supports and bearings. Such as this
                  J
                  Edited By JasonB on 03/06/2013 10:35:23
                  #121387
                  Ady1
                    @ady1
                    Might be easier for home builders if you make it with 16mm silver steel which can even be found on ebay (30 quid delivered)
                    A more seriously beefy machine can always be built with thicker ground bar, if that bar can be sourced by a home builder
                    If the design is good, short lengths of 16mm bar will make an adequate hobby machine
                    Edited By Ady1 on 03/06/2013 10:38:09
                    #121388
                    Hopper
                      @hopper
                      Small motorcycle fork legs come to mind. Usually hard chromed and ground to size. Low mileage parts from a breaker might do the job.
                      #121391
                      Ady1
                        @ady1
                        Stainless at 20 and 25mm can be found quite easily on the netty
                        #121403
                        Ian S C
                          @iansc
                          Automotive shock absorbers are a source of chrome plated steel, you just have to hunt around. Ian S C
                          #121409
                          David Jupp
                            @davidjupp51506
                            Marchant Dice stock this kind of stuff. They already do (or certainly did) kits for the Rockliffe router. They trade on line and via e-bay. Probably lots of other options out there.
                            #121411
                            John Stevenson 1
                              @johnstevenson1
                              Posted by Hopper on 03/06/2013 10:40:20:
                              You must have a little motorcycle, he wants 20mm wink
                              #121415
                              John McNamara
                                @johnmcnamara74883
                                Thank you all for responding.
                                I can source the material in Melbourne OZ from a couple of suppliers fairly inexpensively, I guess it is from Asia but it works well in the router I posted a few weeks back. Although in that case it was the supported kind that comes bolted to an upside down aluminium T section.
                                I don't want to use that type in the new machine due to the added cost of the bearing blocks, and supported rail does cost considerably more.
                                The machine is to be a desktop design, not intended for heavy cutting but it should be accurate. But there is not much point in designing something with difficult to source parts hence my question.
                                A while back actually quite a while I made a machine that used linear bearings running on a unhardened ground shaft. I thought I could get away with it as it was very lightly loaded. At that time there was no Asian revolution and the hardened bar was very expensive. But no go, bad idea. the bar marked badly and It had to replaced with the proper hardened variety.
                                I learnt my lesson, for this machine hardened and ground they will be.
                                Cheers
                                Edited By John McNamara on 03/06/2013 16:15:55
                                #121444
                                Ex contributor
                                  @mgnbuk
                                  http://www.zappautomation.co.uk/en/29-precision-round-rail-supports
                                  A range of sizes available here. I have used this company for (other) parts for work & found them to be easy to deal with & quick to deliver.
                                  HTH
                                  Nigel B.
                                  #121567
                                    Nigel,
                                    Zapp … Useful reference, thanks.
                                    They even provide a Spec Sheet
                                    Edited By Michael Gilligan on 05/06/2013 09:06:53
                                    #121570
                                    Weldsol
                                      @weldsol
                                      You could try Marchant dice
                                      I have used these in the past and have had good service from them (usual disclaimer)
                                      Paul
                                      #121571
                                      John McNamara
                                        @johnmcnamara74883
                                        Yes a good link Thank you Nigel.
                                        It confirms the hardened and ground shaft is available at a reasonable cost, I guess there are other suppliers too.
                                        Cheers
                                        John McNamara
                                          @johnmcnamara74883
                                          And thank you Weldsol too.
                                          With 2 we have a price auction! Good to see.
                                          Cheers
