Hello
I am looking for a material that is:
A. Completely non-magnetic
B. Strength: As strong & abrasion resistant as reasonably possible
C. Size: Available at as a sheet of at least 10x10cm and thickness of 'exactly' 1.0mm (at least 0.97mm, less then 1.1mm)
D. Bonding: Must be reasonably easy to bond with adhesive (e.g. general purpose epoxy resin, or E6000 or CA/superglue)
E. Colour: Must be either black or 'silver' colour
F. Must be machinable. (i.e. I need to be able to sand/machine it.)
G. Needs to be available… fast!
(ideally within 24 hours)
APPLICATION
For indoor use. And normal room temperature. The exact application details are complicated. It is for some scientific testing instrumentation that I am making. It will need endure quite a lot of repeating mechanical impacts & a bit of abrasion…
DISCUSSION
I was thinking about various metals:
– Aluminium?
I was thinking of aluminium but the stuff that I have is rather soft. What would be a strong grade & where could I get it from?
– Copper & Brass
I also have some copper & brass but of course neither of them are silver in colour.
Lead is too soft. Titanium is weakly magnetic. Chromium/Platinum – too expensive
Stainless steel – from memory if it is 'Austenitic' then it should be completely non-magnetic. From my notes, the following grades of stainless steel are Austenitic: 201, 205, 301, 302, 303, 304, 316.
But which grade would be best & where can I get it super-fast?!
I was also thinking about some kind of strong black plastic (e.g. Nylon?) but that's quite hard to glue.
Any suggestions?
Thanks
Donnie
Edited By Donald MacDonald 1 on 27/04/2022 21:42:15
