Looking for a 1/4″ ratchet
Home Forums General Questions Looking for a 1/4″ ratchet
Viewing 25 posts - 1 through 25 (of 38 total)
  • #283188
    John Stevenson 1
      @johnstevenson1
      Not a 1/4" drive as such I want a hollow ratchet with 1/4" hex hole in it so I can directly drive the 1/4" replaceable screwdriver and allen key tips.
      Sure I have seen one but as soon as you type in 1/4" drive you get every socket set supplied by man and beast.
      Any clues ??
      This is for getting in some real tight spaces.
      [EDIT]   Got the 1/4" square ratchets where you have an adapter from square to hex but this makes the overall high too great.
      Edited By John Stevenson on 08/02/2017 22:08:11
      John Stevenson 1
        @johnstevenson1
        #283191
        Nick_G
          @nick_g
          Do you mean like a 'normal' ratchet but instead of a 1/4" sq male drive sticking out the ratchet has a female 1/4 hex socket.?
          Nick
          Edit :- if so https://www.amazon.co.uk/BERGEN-Female-Ratchet-Spline-BER4077/dp/B00OBFG6VM
          Or
          https://www.amazon.co.uk/d/Home-Kitchen/Sealey-AK6962-Driver-Ratchet-Stainless/B00K1UNJ52/ref=pd_bxgy_60_img_2?_encoding=UTF8&psc=1&refRID=QPW3A78BEWFB41JJ4VHH
          Edited By Nick_G on 08/02/2017 22:23:36
          #283192
          John Reese
            @johnreese12848
            Does Amazon serve the UK? They list several.
            #283193
            Andy Holdaway
              @andyholdaway
              John, here's one but it's a bit pricey. I bought a really cheap one a few years ago from Lidl but haven't seen them since.
              Andy
              edit: Nick beat me to it, although it's a different one.
              Edited By Andrew Holdaway on 08/02/2017 22:25:42
              #283198
              Les Jones 1
                @lesjones1
                I found this one on ebay. And also this one.
                Les.
                #283199
                  Maplin does [or did] one by Pro'sKit
                  "Offset Ratchet & Socket Driver Set"
                  1PK-202A (Metric Size)
                  1PK-202B (Inch Size)
                  Same ratchet, different sockets
                  Has 1/4" square male one side and hex female t'other.
                  Alan Waddington 2
                    @alanwaddington2
                    I've got a couple of Teng ratchets like you are describing, but they come in small sets with a range of 1/4 bits £30 or so, well worth the money,, great quality, lifetime guarantee. They do a couple of variations, but the difference is the bits rather than the ratchets.One of my sets has sockets up to 13mm and a hex to square adapter to mount them to the ratchet.
                    http://www.ebay.co.uk/itm/Teng-TM029-29pc-ratchet-1-4-screwdriver-socket-bit-set-Pz-Ph-Slot-Tx-Tpx-Rob-Hx/262380325394?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3Df1a1b8cc7d7c4f5a8f78857fb7e4ad1e%26pid%3D100338%26rk%3D1%26rkt%3D15%26mehot%3Dag%26sd%3D291446632415
                    Edited By Alan Waddington 2 on 08/02/2017 22:53:35
                    #283201
                    Michael Briggs
                      @michaelbriggs82422
                      Hello John,
                      I can recommend this Wera reversible ratchet, sold as a set here but you can get the ratchet for about £20, top quality, as reflected in the price. The overall length of the ratchet is 87mm or 79 mm from the centre of the hex socket to the end of the handle:
                      Regards, Michael
                      #283204
                      duncan webster 1
                        @duncanwebster1
                        from the 'well known auction site'
                        you can also getsets of ratchet spanners for about the same price, no idea on quality
                        #283209
                        peter walton 1
                          @peterwalton1
                          Hi John,
                          Try this **LINK**
                          Good quality and small in size.
                          peter
                          #283210
                          Mike Poole
                            @mikepoole82104
                            Search fo Bahco 2058s26, I have this set as it fits in your pocket and was handy when I used to go to work, in fact it is still handy even though I don't work any more.
                            #283217
                            John Stevenson 1
                              @johnstevenson1
                              Mike, are the sockets 6 sided or 12 sided.
                              I know I didn't ask but it's for another application
                              #283219
                              peak4
                                @peak4
                                John, I've been using one of these for a while now, quite compact, and got me out of various difficulties.
                                Mine came from Clas Ohlson in Doncaster for about a tenner, but sadly they've now closed.
                                I should be able to sort you out some close up photos and measurements if you need them, just let me know.
                                For other readers, these are on offer at Aldi at the moment, probably too big for John's application, bit worth investigating for other uses; I find them quite handy on the motorbikes.
                                Bill ( the ugly bugger with the beard and the 3/4 flute core drills @ Doncaster last year)
                                #283222
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi John, here's another **LINK** and **LINK**
                                  Regards Nick.
                                  #283225
                                    John just put "1/4 hex ratchet" into your favorite search engine rather than 1/4 frive and you will get loads of them , Wera are OK, though I use one like this
                                    Edited By JasonB on 09/02/2017 07:29:28
                                    #283226
                                    Ex contributor
                                      @mgnbuk
                                      I use a Wera 8001 1/4" ratchet bit driver, like this :
                                      RS Components used to sell them (where I got mine from), but I can't find it now with their hopeless search engine.
                                      It is very small, but beautifully made & gets into very confined spaces – it has got me out of trouble on many occasions. Not cheap, but very worthwhile.
                                      Nigel B
                                      #283230
                                          Neil problem withusing a ratcheting spanner is that don't have any means to retain the screwdriver bit so it either drops out also you can't apply any pressure to it to keep it in the screw head as the spanner just slides along the shank.
                                          J
                                          #283233
                                            Simon Williams 3
                                              @simonwilliams3
                                              John I sent you a PM.
                                              HTH Simon
                                              #283248
                                              peak4
                                                @peak4
                                                Lots of links to plough through there John; this is the one I was referring to earlier.
                                                I quite like it as one end has a plain hex for loosening tight screws without fear of damaging the ratchet, plus there's a spring retainer for the bit at both ends
                                                Stanley 1/4 hex ratchet
                                                All the best
                                                Bill
                                                Edited By peak4 on 09/02/2017 09:45:02
                                                #283256
                                                  Posted by JasonB on 09/02/2017 08:10:17:
                                                  A problem nicely avoided with the Pro'sKit ratchet that I mentioned yesterday **LINK**
                                                  http://www.proskit.com/screwdrivers/multi-purpose/offset-ratchet-with-sockets
                                                  …. and several others, of similar style
                                                  Mike Poole
                                                    @mikepoole82104
                                                    Posted by John Stevenson on 09/02/2017 00:47:44:
                                                    The ones in my set are six sided with 1/4 square drive, a hex to square adaptor is in the set to drive the sockets, the hex bits fit directly in the ratchet or there is a extension if required.
                                                    #283263
                                                      Posted by Michael Gilligan on 09/02/2017 10:31:15:
                                                      The second one I linked to avoids this too.
