Thanks for the tips,
I got it Sussed
. First attempt was a failure, second third and forth all improved and set up time is down to 20mins. I learned my mistake. I was clamping chuck end to firmly to soon. I found if I clamp the jaws loose about .002" move to the tail, tap to get within .002" and repeat the process slowly increasing clamping force I can get to almost zero both ends. I also found my punch mark was way to aggressive and the centre just kept springing the stock back.
So my method goes, mount stock with sleeve and steady in place, indicate either side of set up ( difficult with the limited space), put fingers of the steady in place and then remove tail stock/centre and a final indicate🙂.
Thanks once again for poking me in the right direction, I'm well happy, I thought something was drastically wrong.
Woody.
