Long span shelving – support material
Home Forums General Questions Long span shelving – support material
Viewing 25 posts - 1 through 25 (of 39 total)
  • #646881
    Puddleglum
      @puddleglum
      Hi,
      Not model engineering, but hopefully there are folks with experience knowledge that can help…
      I have a space above my garage door that I'd like to use as a storage area. To do so, I need to run shelf supports across the 3 meter width of the garage.
      My initial thought was box section mild steel… I imagine that I'd need something rather beefy – but can't decide just how beefy.
      Then, having thought about box section, started thinking about rusting from the inside out – so maybe angle iron that I can paint is a better option. Found some that is 40mm x 20mm x 4mm thick – but is this too wimpy?
      Was thinking 3 supports – front, back and centre. Load to bear – say 200kgs
      Thoughts welcome.
      Puddleglum
        @puddleglum
        #646884
        Pete Rimmer
          @peterimmer30576
          4mm thick is miles too heavy. My high-level shelving is made from 40x40x1.6mm thick and it spans 2m+. It's loaded up to the nines with no sign of distress.
          I've even made a rack to hold the working heads from my mill which are up to 50kg each. The rack is just short lengths of this same box section welded to the wall frame one end and they too seem to hold up with no issues.
          #646885
          Puddleglum
            @puddleglum
            Posted by Pete Rimmer on 29/05/2023 17:11:07:
            Cool, thanks. I am prone to over-engineering over-thinking designs
            #646887
            Nicholas Farr
              @nicholasfarr14254
              Hi Puddleglum, 3 metres is quite a wide span for anything without a bit of depth to it, and a beefy bit of box section will be heavy, rust inside would be the least of you problem, but you can put those plastic bungs in the ends which would slow down the process. Lightweight rectangular section, say 80mm deep would be better, but better still would be to have a central support from the roof, if it's strong enough. Bearing in mind that the larger section you have, the more expensive it will be. 40mm x 20mm x 4mm would be OK if you made a Lattice type beam of a suitable deepth.
              Regards Nick.
              #646890
              Maurice Taylor
                @mauricetaylor82093
                Hi , I think it would be easier for members to give answers if you put photos of location of shelf on.
                Maurice
                #646891
                DiogenesII
                  @diogenesii
                  3m wide, but what's the front-to-back depth of the space?
                  #646892
                  Puddleglum
                    @puddleglum
                    Posted by Maurice Taylor on 29/05/2023 17:49:21:
                    Maurice
                    Not really anything to show – 2 walls, 3m apart. To run a shelf across, will need support "beams" that span the 3m. As they'll only be supported at the ends, worried about deflection bending failure.
                    Edited By Puddleglum on 29/05/2023 18:00:26
                    #646893
                    Puddleglum
                      @puddleglum
                      Posted by DiogenesII on 29/05/2023 17:50:49:
                      That's kind of irrelevant… but about 600mm.
                      Edited By Puddleglum on 29/05/2023 18:00:45
                      #646895
                      Puddleglum
                        @puddleglum
                        Does this have supports in the middle, or just the ends?
                        #646897
                        Puddleglum
                          @puddleglum
                          Posted by Nicholas Farr on 29/05/2023 17:36:39:
                          Yep – it's a fair span. What got me thinking it might be possible was the pallet racking in warehouses. Like this. Doesn't say what the cross section dimensions are though
                          Unfortunately, not possible to add central support from roof
                          Edited By Puddleglum on 29/05/2023 18:18:55
                          #646898
                          Pete Rimmer
                            @peterimmer30576
                            Posted by Puddleglum on 29/05/2023 18:03:03:
                            Supported either end, cross-bars between the front and rear spans every couple of feet just to support the chipboard shelf.
                            If you want to know about deflection for 200kg load just get a piece of the steel, span it across and get two chunky people to hang on it in the middle.
                            #646899
                            Puddleglum
                              @puddleglum
                              Posted by Pete Rimmer on 29/05/2023 18:16:06:
                              Ah cool
                              smiley It might come to actually testing – was hoping to avoid ending up with a bent 3m length of box rectangle that I haven't a use for
                              #646900
                              Peter Cook 6
                                @petercook6
                                There are several free beam calculators on the internet that will let you do deflection calculations. You can test out various materials and cross sections without risking your box section – or the bodies you hang from it!
                                #646904
                                Maurice Taylor
                                  @mauricetaylor82093
                                  Hi,Have you considered using 4 x 2 timber ,I’d use 3 pieces of 4 x2 to span the garage and put a piece of 18mm plywood on the top of it . Cheaper and easier than steel.
                                  Maurice
                                  #646905
                                  Puddleglum
                                    @puddleglum
                                    Posted by Peter Cook 6 on 29/05/2023 18:50:56:
                                    It might be I'm a bit thick – but the ones I found required all sorts of parameters I haven't a clue about. Unless you could kindly point me in the direction of a simple one…?
                                    #646907
                                    Puddleglum
                                      @puddleglum
                                      Posted by Maurice Taylor on 29/05/2023 19:08:29:
                                      Maurice
                                      Yes, I considered 4x2s, and my gut feel is they'd deflect over time.
                                      #646909
                                      DC31k
                                        @dc31k
                                        What is above the proposed shelving?
                                        If there is a way to support it midspan, that will help a lot. Could be as simple as a piece of rope tied to the ridge timber.
                                        The 4" x 2" timber and plywood has a structural depth of over 100mm. That might be a consideration if headroom is limited.
                                        The 200kg person hanging on the middle will give a conservative over estimate of the deflection as the 200kg load is distributed evenly over the 3m x 0.6m area, and shared between more than one support.
                                        #646912
                                        John Doe 2
                                          @johndoe2
                                          I am having difficulty visualising this. For medium loads, I put supports every 700-800mm. and use 18mm thick plywood sheeting cut in strips.
                                          #646913
                                          JA
                                            @ja
                                            My only comment is that the shelving will be rather high up. OK when you are young and middle aged. I now find all my high shelving, above 65", slightly difficult to reach. I put a shelf above one garage door and have not been there for years.
                                            JA
                                            #646916
                                            martin haysom
                                              @martinhaysom48469
                                              could put more than one beam from side to side to increase load capacity
                                              #646919
                                              Puddleglum
                                                @puddleglum
                                                Posted by JA on 29/05/2023 20:22:10:
                                                JA
                                                Worry not – step ladder. It's for the stuff that is in the "I don't often need it, but I will probably need it in future" category.
                                                #646920
                                                Puddleglum
                                                  @puddleglum
                                                  Posted by martin haysom on 29/05/2023 20:39:22:
                                                  Yes, minimum of 2, maybe 3 or 4. Working out what the minimum needed would be.
                                                  #646933
                                                  Mike London
                                                    @mikelondon
                                                    Have you considered "Dexion"?
                                                    Deep angle section without the weight. For extra strength bolt two lengths together back to back to create "T" section.
                                                    Can be found second hand quite cheaply, from various sources. I use it all over the workshop.
                                                    #646935
                                                    John Doe 2
                                                      @johndoe2
                                                      You could go for 4 supports but I would advise that you go for 5, which would mean you would never need to worry about overloading, nor about the shelf sagging between the supports.
                                                      Assuming an inset of 20mm from each end; the shelf support centres will need to be at;
                                                      20mm
                                                      760mm
                                                      1500mm
                                                      2240mm
                                                      2980mm
                                                      As measured from one end
