long case clock
long case clock
Home Forums Clocks and Scientific Instruments long case clock
  • #3742
    Lynne
      @lynne
      Plate Threads
      Lynne
        @lynne
        Hi, wheel posts are threaded 3BA, so the spares catalogue tells me
        The tapping hole for 3ba is 29 or 3.4mm, and these will not go through the hole in the plate I am looking at. I have tried to determine the thread from the range of taps I have , but no success. Any suggestions as to what may have been used.
        Thanks, Lynne
        #264515
          Lynne,
          What clock & what catalogue ?
          Bob Stevenson
            @bobstevenson13909
            ………..Michael beat me to it!……..
            If you want to know what thread then shave down a spill of softwood and (carefully) screw it into the threaded hole then compare with a thread guage.
            "wheel posts" are usually called 'arbours' but they are not usually threaded…….
            #264517
            julian atkins
              @julianatkins58923
              Hi Lynne,
              If you want a pukka traditional job the frame posts are secured with tapered pins, not threaded and with nuts added.
              Cheers,
              Julian
              #264528
              Brian Wood
                @brianwood45127
                Hello Lynne,
                ​Please forgive me for gate crashing your post, but I have sent a PM to Bob Stevenson and wanted to catch his eye while this is still current.
                ​Brian
                #264532
                Bob Stevenson
                  @bobstevenson13909
                  …..Hello Brian,…I have sent you an email just a minute ago!
                  #264613
                  Lynne
                    @lynne
                    Thanks for the responses.
                    Michael & Bob. 8 day longcase, english movement, well, the name on the brass face is Geo. Booth, Manchester. Hasn't ticked for 40 years that I know of. Weights, one cast iron, could be original, the other, pretty poor lead casting. Also missing the gathering pallet, which will be a challenge. The hands need attention, minute hand broken, but I have the pieces. There is more.
                    Catalogue. Meadows & Passmore. They describe them as Rack & minute wheel studs. Cousins describe them as Rack & lifting piece posts/studs. The 22mm length is insufficient, I need 25mm, so I will have to do a repair. Minute post is sound, Maj. thread dia. is 3.43mm, hole dia. 3mm. tread pitch using BA guage would appear to be 3BA.
                    So, what to do? drill 3.4 and tap 3BA, or try to match the original form. Regards Lynne
                    #264619
                      Thanks, Lynne
                      Here's the Rack Stud, for everyone's reference **LINK**
                      http://www.m-p.co.uk/muk/parts/chap03/rack-stud-1459000315.htm
                      Proper 'conservation' would mean modifying the new component [or making from scratch] to fit the existing tapped hole … but only you can decide whether that is appropriate.
