Howard, can’t fault you for enjoying the sunshine, enjoy it while it lasts!
As Sid said, knowing which browser you’re using would help us no end, also, are you using any kind of password & username software? the sort of programme similar to a digital vault that stores them separately from either Windows or browsers?
I think one variety is called ‘logmein’ or some such handle!
Sid, I’m no software evangelist, but software is like medication, depending upon how it is used and who is using it, some of it will kill some poople, and for some it’s a lifeline, similarly I wouldn’t tar all programmes by the same brush, as some people dick around with their pc’s when they haven’t the feintest idea what they’re doing, when in most cases if things go pearshaped, it’s a simple issue of re-installing a back-up…………..which many of those afflicted probably didn’t do!
I’m the first to walk away from dodgy software, and having been building and maintaining my own computers since the early 90’s on DOS and Intel 286 pc’s, I’ve seen a few applications come and go I can tell you.
CCleaner is well respected, well proven and has been around a very long time, I’ve never in all the years I’ve been using it, had an issue, and even if there was an issue, with Windows these days, it’s usually a simple matter even from safe mode, of going into ‘system restore’ and selecting an earlier restore point which will undo all changes made.
With CCleaner, anything done to the registry is backed up (you’re given the option to save but you would be insane to click ‘no’), and if things don’t work out, you right click on the saved file, and select ‘merge’ and it will put everything in the registry back to square one!
