You can buy a lot of expensive adhesives from people whose job it is to sell it, and spend lots of time experimenting, only to find out:
1. it kind of just barely adheres to the low surface energy acetal parts, a very weak bond.
2. if the parts flex at all, or any load is applied, weak bond breaks.
3. If the temperature changes, weak bond breaks.
4. You then spend many hours in calls to the manufacturer / salesmen listening to excuses about field conditions being different from test lab conditions, questions about did you get it clean enough, dry enough, rough enough, with the right additives / accelerants etc, did you wait long enough, and looking at beautiful test charts. Bonding Failures will always be your fault, not the adhesive makers.
5. The salesmen will start to suggest special treatments to change the surface energy of the parts, like laser etching or corona discharge. If you go down this route, expect huge equipment costs and no tangible improvement, and no warranties or return policy whatsoever on the equipment.
6. After some time interval doing the above you will not be able to reach the sales people any more, or you will be told they have moved on to a company selling toilet cleaner, artificial fingernails, cars, etc (or prophylactics, in one case)
The above is based on multiple experiences trying to glue polymers in industry, much of the time spent trying to glue acetals and polyethylenes .
Acetal is NOT like other plastics that glue well, or metals that bond well with anaerobic adhesives.
