Loctite and similar materials
Home Forums Materials Loctite and similar materials
  • #29610
    Danny M2Z
      @dannym2z
      Danny M2Z
        @dannym2z
        G'day.
        On some threads I have noticed that 'Loctite' is used as a generic description for a bonding material/ thread locker or similar uses.
        The word 'Loctite' appears to have slipped into general terminology, but without mentioning the type/grade it is as useless as saying glue part A to part B without describing the materials or type of adhesive.
        Loctite works well, so do many of it's competing products – if used correctly for the application. There are a vast range of substances tailored to specific applications.
        When such products are mentioned, it would be useful if the specific variety was identified and even more interesting – Why was it selected?
        (I have nothing to do with Loctite btw)
        * Danny M *
        #245376
        MW
          @mw27036
          Hi, i use a bearing and shafts grade of Bondloc, comes in a black tube, a UK variety, it's reasonably priced and i've noticed it's "glupy-er" than the regular variety of loctite.
          My original reason for buying was simply a buy 1 get 1 free deal, i suppose loctite would do their own variety of my selected grade but i've stuck with that ever since.
          Michael W
          Edited By Michael Walters on 04/07/2016 11:45:22
          #245378
            Posted by Danny M2Z on 04/07/2016 11:38:09:
            Loctite … < etc. >
            Good luck with this, Danny … I have been trying for years, with little success.
            P.S. … Now that Henkel is using 'Loctite' as a brand-name for a wide variety of products [not just the 'anærobics'], this is more important than ever.
            Edited By Michael Gilligan on 04/07/2016 12:21:06
            #245384
              Just for emphasis : **LINK**
              Yes … There really is a range of Loctite lubricants crying 2
              Oxymoron or just moronic marketing ?
              Bob Brown 1
                @bobbrown1
                I think it is important to use the correct product for what you are trying to achieve.
                e.g. A product to retain nuts is not the ideal product to retain a component on a shaft or a bearing in a housing. Some are high strength and not designed for easy removal where others do allow the bond to be broken with out too much effort.
                On top of that there is a temperature consideration as some are suitable for high temps where others will fail.
                Good place to start if considering a Loctite product **LINK**
                #245391
                MW
                  @mw27036
                  Well most of them will fail under heat. You can even use that to your advantage.
                  Michael W
                  #245393
                    I think Bob was refering to using a suitable product to restist the temperature that the parts are likely to reach, such as 648 if sticking a liner into a steam engine cylinder rather than a lower spec flavour that may fail when you don't want it to.
                    #245398
                    Roderick Jenkins
                      @roderickjenkins93242
                      #245402
                      Ajohnw
                        @ajohnw51620
                        Loctite did produce a little booklet that gave info on what grade to use etc. Then they were taken over and even their web site taken down and replaced with near zero information. Looking at the site now things have improved.
                        Rather a long time ago I designed something at work that needed putting together with a bit of use of a screw driver and soldering plus gluing. As they didn't know who to put the job out to I finished up making them up at home – on piece work, the pay was fantastic. These involved the use of 2 grades of loctite super glue. I suspect all that has happened in this area is that availability is a lot more widespread. My impression was that they used to be a purely industrial product. I've also used adhesives of EVO that are only available to industry. CIBA too so it's not that unusual.
                        I'm glad the super glues are easy to get now. I usually have a bottle about. It lasts a long time providing that the excess is sucked back into the bottle and none cures on the tip of the applicator.
                          Posted by Roderick Jenkins on 04/07/2016 15:41:12:
                          Other manufacturers' products are available
                          wink
                          Rod
                          Very true **LINK**
                            Although this cross-reference does not appear to be exhaustive, it's a useful start.
                            … Can anyone find a better one ?
                            Ian S C
                              @iansc
                              I found at least 16 manufacturers on Google. for Loctite lots of info.
                              Ian S C
                              #245604
                              Ian S C
                                @iansc
                                For fitting the aluminium plug in the cool end of the displacer for Stirling Engines I have been using the high temperature, high strength grade of "Loxeal", can't remember the number, I have also used it to attach a flange on the hot cap of a number of motors.
                                Ian S C
                                #245616
                                Hopper
                                  @hopper
                                  Posted by Ian S C on 06/07/2016 10:00:28:
                                  ….I have been using the high temperature, high strength grade of "Loxeal", can't remember the number, ..
                                  And herein lies the reason many posters just say "Loctite" and don't quote the number. The tube is out in the shed and they can't remember the exact product number. Really, it's up to the enquirer to look up the product data and choose exactly which grade of product suits their particular need.
                                  #245627
                                  Stephen Benson
                                    @stephenbenson75261
                                    My Downham milling machine has a 20mm collet installed and I make all my tools with a 20mm shanks I have a 12mm end mill Loctited (Retaining Compound 638) in with a thou or two clearance and when I want to replace it I just heat it up with butane torch pull out the old cutter wait for it to cool then Loctite in the new. it is amazing stuff use it to retain all my clock wheels never had a problem.
                                    #246928
                                    Ian S C
                                      @iansc
                                      Bought half a dozen cap screws on Friday, and they gave me six 2 mil tubes of Vibra Tite 12102 Blue medium strength removable thread lock for 1/4" to 3/8" threads, the packing says it competes with Loctite 242.
                                      Ian S C
                                      #247040
                                      John Olsen
                                        @johnolsen79199
                                        Just to add to the confusion, Loctite themselves have changed the numbers over the years.
                                          Loctite-spotters might be interested in this ebay listing:
                                          http://www.ebay.co.uk/itm/Loctite-303-Gluing-Robot-glue-dispenser-and-UV-Cure-chamber-Curing-cabinet-/291807092335
                                          Edited By Michael Gilligan on 30/07/2016 06:40:05
                                          #248600
                                          Peter Krogh
                                            @peterkrogh76576
                                            Just about all you want to know is on the Henkel web site:
                                            http://na.henkel-adhesives.com/loctite-industrial-assembly-repair-13281.htm
                                            Pete
                                            #248604
                                              Danny,
                                              I am guilty of dragging this thread off-topic blush
                                              For my pennance I have quoted the very clear, and important, message from your opening post.
                                                Navigating the ever-more-specialised range of products is becoming difficult
                                                Example: Today I was trying to remember which grade I used on the last pair of spectacles [to stop the tiny screws coming out, but not locking them so hard that they shear-off when lens replacement comes due] … My choice was between 222 and 225 … but are they the same strength?
                                                This document provides a very convenient reference in such situations: **LINK**
                                                http://www.loctite.co.uk/uke/content_data/366607_48801_MoD_Brochure_lo.pdf
                                                It's worth downloading.
                                                  Just a thought, the most important distinction is between 'superglues' which are cyanoacrylates that are cured by moisture and anaerobic adhesives which are all the specialist thread lockers, studlock etc. etc. etc. that cure in the absence of oxygen.
                                                  'Loctite' is a brand and covers both types of adhesive, which adds to the confusion.
                                                  Out of interest, Gorilla Glue (the brown one once known as 'Gorilla Snot&#39 is a polyuerethane-based adhesive used by applying to one surface and spraying the other with water.
                                                  The cheapest bulk source of 'superglue' is so-called 'mitre bond' which comes as a bumper bottle of adhesive plus a spray activator.
                                                  #273412
                                                  Nick Hulme
                                                    @nickhulme30114
                                                    http://www.bondloc.co.uk/threadlockers/
                                                    Other brands are available.
                                                    There is no guesswork involved, just a little reading around the subject,
                                                    – Nick
                                                  Home Forums Materials Topics
