The usual clearance should be of the order of 0.002 – 0.003" (0.050-0.076 mm )
The parts should be cleasn, and free of oil or grease.
I used Loctite between the faces of a collet chuck and a fabricated backplate, to hold them oncve the nbtaper hadv been clocked trur and nthe bolts tightened.
When I wanted to separate them, to fit the chuck to a machined cast backplate., they could not be separted.
Really heavy blows with amallet would not shift them, so theyb remain together.
