Loc Tite
Loc Tite
Home Forums Workshop Techniques Loc Tite
  • #495956
    Alan Gordon 4
      @alangordon4
      Hi everyone. I had to secure a component on a piece of 5mm drill rod with loctite to carry out further work. In order to remove the component I had to heat it up to enable me to remove it from the shaft. However I want to get rid of the residual loctite still within the bore, I dont want take the chance of damaging the bore so is there a chemical that i might use to removed the loctite ?
      Alan Gordon 4
        @alangordon4
        #495971
        Brian Wood
          @brianwood45127
          Hello Alan,
          Try drilling it out using a 5 mm drill, with the drill held in a pin chuck so the the operation is done by hand
          Regards Brian
          #495980
            From the 638 technical data sheet :
            “Cured product can be removed with a combination of soaking in a Loctite solvent and mechanical abrasion such as a wire brush.”
            … It’s pretty resistant to most solvents !
            Alan Gordon 4
              @alangordon4
              Hi Brian,
              Yes i thought about this but the hole is reamed to 5mm and the component will eventually go back onto a 5mm shaft. So I am trying to maintain the reamed dimension, my thoughts are with trying to dissolve the residue out rather than mechanically remove it.
              #495982
              Alan Gordon 4
                @alangordon4
                Second thought ! I wonder if "Super Glue" solvent would work ?
                Edited By Alan Gordon 4 on 15/09/2020 18:29:52
                #495984
                Howard Lewis
                  @howardlewis46836
                  You might have difficulty finding chemicals to remove the cured anaerobic, so, as Brian says, you will have to use mechanical means.
                  You may have problems looking down a 5 mm hole to see when all has been removed. Although if the rod was 5 mm the hole is likely to be oversize by about 0.025mm so making a nat's bigger may not matter that much.
                  Rolled up Emery perhaps?
                  Howard.
                  #495985
                  Alan Gordon 4
                    @alangordon4
                    Interesting Howard, thank you
                    #495992
                      Posted by Alan Gordon 4 on 15/09/2020 18:29:04:
                      What grade of Loctite did you use ?
                      … I only chose 638 to reference in the absence of any detail.
                      Robert Atkinson 2
                        @robertatkinson2
                        #496005
                        old mart
                          @oldmart
                          Using the same reamer with plenty of oil would be my first thought. It is very difficult to enlarge a hole that has already been reamed. Make a test piece first out of the same material if the original hole is critical.
                          #496007
                          alan-lloyd
                            @alan-lloyd
                            Try nail varnish remover, or print head cleaner – acitone
