The supplied white grit wheel for the Worden is fine for HSS tools, remember it is NOT a bulk metal remover. Any shaping of a HSS tool needs to be done on an offhand grinder first.
For Carbide tooling then buy the diamond wheel kit and make it up. Again only use minimal removal rates or it will burn or clog. Average feeds of 1/2 thou seem good.
Using collets, it is fine for shapening the ends of carbide milling cutters.
One thing I have found is that the Worden table is not square/ parallel to the wheel! and you should check the rake angle very carefully against the vertical face of the wheel. Using a rather small angle sticker to set the angle is not too good and i will later make and fit a larger more accurate with well maked angles for easier settings.
As an aside, i have found that the clamping screws tend to work loose for some reason on the bodies of the wheel arbors, anybody found this and have a solution?
I would also like to see a 4 facet drill jig that will work on the Worden.
Edited By Clive Hartland on 04/05/2013 12:43:56
