Of course I'm biased, as I'm building from the LSM imperial drawings. My castings are from elsewhere and follow the original Filby design in some areas, so the LSM drawings are not appropriate. There are a number of show stopping errors, and a lot of missing detail, in the LSM imperial drawings. I'd be surprised if they had been corrected in the metric versions.
As I mentioned to Karl yesterday at the Forncett exhibition day one area that has gone metric is sheet and plate. So 1/4" plate for the hornplates is simply not available. I used 6mm plate which necessitated changing the dimensions of some other parts. However in other areas the situation is more complicated. I've just looked at the rear axle material, specified as EN8 and 1-5/8" diameter. Looking at my local steel stockholder 1-5/8" is no longer available for order. Both 1-1/2" and 1-3/4" are available and in stock. The metric equivalent is 41.275mm. The nearest listed is 42mm, but this is not available for order. The only size that can be ordered is 45mm, which is on 14 days.
An interesting question is what have LSM done with the gears. The DP values do not correspond exactly with standard module sizes. So changing to module would require some significant changes to centre to centre distances, which has a number of knock on effects. Similarly have they made new patterns for castings, or are the castings still based on the imperial design?
When I started I planned to change all threads to metric. Internally I used a number of metric, mainly M6, SHCS and will continue to do so. But externally they just don't look right, so I've reverted to BSF and BA. Since I'm making most of my own bolts, studs and nuts, availability of off the shelf items isn't important. Nor is the availablility of the correct hex AF stock, as I use sizes that correspond with the hex collets I have available rather than what is nominally correct.
My lathe is imperial and both manual mills are metric. Generally this is not a problem either way. However, as NDIY says the main issue is metric screwcutting on an imperial lathe. I tend to screwcut a lot of my threads, a number of which are specials. The imperial drawings call out a number of BSP and 32 & 40tpi ME threads for which there are no direct metric equivalents. Before anyone points it out I know that there are ISO pipe thread standards, but they're based on the BSP system. So for 3/8" BSP you'll still need to be able to cut a 19 tpi thread.
