Live steam Globe valves
Home Forums Locomotives Live steam Globe valves
  • #1619
    Ron Hancock
      @ronhancock63652
      Ron Hancock
        @ronhancock63652
        hi can anyone suggest a good steam Globe Valve. I have bought several from different suppliers but seem to seal for a very short time. I need a 3 1/6 pipe fitting to supply my Injector had new one fitted only two weeks ago it's already seeping
        Ron
        #305646
        steamdave
          @steamdave
          Have you tried the PM Research globe valve? 1/4" x 40 thread available from Forrest Classics
          http://www.forest-classics.co.uk/pm_research_sw-4.htm#Globe%20Valve
          or if you fancy machining your own from castings, have a look at PMR
          https://www.pmmodelengines.com/shop/pipe-fittings/globe-valve-kits/
          They are easy to make up.
          The Emerald Isle
          #305647
            Ron, most globe valves have a right and wrong way round. You need to get them in the right. see here right way round for steam
            J
            Edited By JasonB on 05/07/2017 12:23:11
            #305800
            Henry Artist
              @henryartist43508
              I have found the valves supplied by GLR Kennions to be very good quality. **LINK**
              Sometimes, after a lot of use there can be a tiny leak at the valve stem but it is a simple matter to replace the graphite string packing. You may also like to experiment with O rings.
              Alternatively, you may want to try the valves sold by Bengs Modellbau. **LINK**
              They are made by Winfried Niggel and are rated to 6 bar.
              #508536
              Greensands
                @greensands
                Can anyone please expand on the idea that a globe valve has right and wrong way around. The link given in a previous post is now dispslaying the dreaded "404 Not found" messag
                #508540
                J Hancock
                  @jhancock95746
                  Pressurised side is under the disc, so that given a reasonable shut-off , the valve spindle packing can be changed
                  safely when fully closed.
                  #508543
                  Harry Wilkes
                    @harrywilkes58467
                    Beware with PM fittings quality very good but threads are to US standards
                    H
                    #508545
                    Harry Wilkes
                      @harrywilkes58467
                      As posted by Greenlands your link brings up a page error
                      H
                      Posted by JasonB on 05/07/2017 11:49:04:
                      J
                      #508603
                      mechman48
                        @mechman48
                        Hi Ron, think along the lines of.. steam moves along the pipe from the boiler, then goes UP against the bottom of the disc, which lifts & allows steam over the top of the weir & into the discharge line of the valve… think 'along – up & over – along'. I know from my time repairing valves that industrial valves have an arrow to show the flow direction cast in the body & so which way the valve should be fitted. Google 'globe valve diagrams'.
                        George.
                        #508605
                        mechman48
                          @mechman48
                        Home Forums Locomotives Topics
