OK – Let's try again James.
1) Is there a requirement that all newly produced boilers have a CE marking?
Only if that boiler is commercially produced and has a total volume of 2 Litres or more – otherwise it should NOT be marked.
Should you take a CE marked boiler to a Boiler Inspector – he will apply this guidance:
"A Boiler Inspector shall check that any CE Markings (where required by the Pressure Equipment Regulations 1999 No 2001 and The Pressure Equipment (Amendment) Regulation 2002 N0 1267). Boilers built commercially after 30 May 2002 which do not bear the appropriate CE marking shall not be tested" [Green Book – Revised Edition 2012) – Paragraph 6.4]
2) What legislation affects Live steam boilers in this size range (3-5" )
"Legal requirements, such as the Pressure Systems Safety Regulations 2000 (PSSR), do not normally apply to persons operating pressure equipment as a hobby activity. However the H&SE considers it good practice for persons using such equipment to provide the same level of health and safety protection as they would if they were duty holders under the regulations. To aid this process the principles of PSSR have been followed in drafting this document, which has been prepared after consultation with… (too many organisations to type here) " Quoted from the current Green Book – Para 1.2
3) "With the further possibility of marketing my design along with a boiler bought from a boilermaker."
You seem to be suggesting that you would like to sell your own boiler 'design' (or finished boiler?). A "design" (for others to build privately) would fall under Section 5 in the Green Book titled "Design Verification" and if not previously published (e.g. well proven ) would need to have clear drawings, adequate strength (by calculation) and a clearly stated working pressure – for the Boiler Inspector to examine and check.
I have no idea of what would be required to obtain a 'CE' mark – as that lies outside of a Boiler Inspectors remit.
Finally – as Bazyle has already stated, you do not need any boiler certification to use a boiler privately – although you will need the appropriate documentation should you wish to attend any public event (not because of legislation – but because of insurance requirements). In my view it makes great sense to regularly inspect any boiler in use (even privately) – as I assume that your personal safety and that of your family and friends is also important to you.
The current 'Green' book is about to be replaced by a new revision (the 'Orange' Book) which will probably be released in March 2018.
I hope this helps.
IanT
PS Solved the 'paste' problem by using Notepad to strip out any invisible formatting … seemed to work.
Edited By IanT on 23/01/2018 20:57:27
