Well now, I am having to backtrack on what I have previously said. Mint 21 seemingly does have a few problems which, to me, appear unsurmountable. But then, in all fairness, I am using a somewhat hybrid setup, but I have not had these problems before. Anyway, I'm having to remove Mint 21 and use Mint 20.3 instead, the major difference being that End of Life for Mint 20.3 is 2025, rather than the 2027 of Mint 21. Oh well, c'est la vie, n'est ce pas?
The problems I have:
Unreadable desktop at times. I like a black desktop with no fancy graphics and use Mint-X or Mate as appropriate. I have done this for a few years now and have found it totally satisfactory. When selected, the icon & the undertext are both highlighted. Using Mint 21, this highlighting is extreme, such that both the icon and the text are obscured.
Loss of data. One of the advantages of modern computers is that of multi-tasking. I use this when copying data either from one hard drive to another, or inbetween computers. Normally, I can then do something else whilst the copying is going on. Under Mint 21, I was doing this when I attempted to delete some files. The system then completely obliterated on both the donor hard drive and the receiving hard drive all those files yet to be copied resulting in a complete loss of some data. Not good at all.
Problems with Wine. In addition to the DOS program mentioned above, which by the way works ok now with DOSEmu2, I also use DesignCad 3D Max v. 17.2 which is a Win 32 bit program. Now ok, this is another ancient program, dating back to 2005 or thereabouts but it works and does what I want, and whilst there is a modern version of the program, it is expensive. But, with Wine it works at about 98%, and the bits that don't work don't matter anyway. So, install Wine, and then DC17. The first time I set this up using Mint 21, it loaded Wine v.6.x.x. The next time, on a separate computer, it loaded Wine 7.x.x. I think I clashed with WineHQ's changeover, but I could not get it to run properly. Dropping back to Mint 20.3, and Wine installs using v. 7.x.x. and all seems ok, within reason!
Now, for historic reasons I also have a number of data files saved in the proprietary formats for both Paint Shop Pro v.7 (PSP) and for Lotus SmartSuite. Last time I tried, I was unable to read any of these files using either The Gimp or Libre Office as appropriate, so I loaded the original programs into Mint 19.3 (yes, not a mistake, 19.3) with the intention of using Wine and thus being able to open these old files. Attempting to do this, under Mint 20.3 or Mint 21 was not good which does rather suggest the problem may lie with Wine 7.x.x. Fortunately, I have now discovered that Libre Office can open the Smartsuite files and as PSP appears to be usable under Wine, then I will be able to convert those data files if necessary.
Apparently, it is possible to use earlier versions of Wine, according to something I came across on the WineHQ site, but it was too late to bother with. And anyway, it does seem that I may not need to bother.
Overall then, although my initial attempts to update to Mint 21 seemed possibly ok, all in all, it's not ok, and therefore I have had to revert to using Mint 20.3. Still, it isn't all bad – I've now got at least a further 2 1/2 years before reaching End of Life. So maybe Silly Old Duffer/Dave has a good point in not automatically upgrading to the newest and latest version of anything.
Cheers
Peter G. Shaw
