linear bearings for milling machine
  • #98386
    ntambomvu
      @ntambomvu
      Does anyone have information about the use of linear bearings as the beds
      in homemade lathes and milling machines??
      ntambomvu
        @ntambomvu
        #98639
          Welcome aboard, ntambomvu
          Not specifically … but they do work very nicely on microscope stages and such.
          The steady load capacity can be astonishingly high, but I suspect you may have problems [bearing tracks pitting] caused by vibrations that are transmitted from the cutter. It really depends what sort of work you are expecting the machine to do.
          … A heavily built machine, taking light cuts, could be fine.
          What do you have in mind?
          Edited By Michael Gilligan on 17/09/2012 21:51:34
          #98641
          John Stevenson 1
            @johnstevenson1
            Most commercial machines now use linear bearings for the bed ways instead of slides.
            #98663
            ntambomvu
              @ntambomvu
              Hello Micheal- nice to meet you
              I recently bought a cheap bench lathe and have fitted it with servos and am running mach3
              There have been many problems. Fitting limit switches,fitting home switches making fittings for the ball screw – routing wiring away from interference ( mechanical and electric) ts.
              Other issues are that the gearbox is noisy and the speed range is inadequate.
              So instead of messing around with something of known dubious quality- I am going to
              convert it back to original and rather build myself a new all electronic lathe. I am sure it will
              probably be cheaper ( and better) than trying to work with something junky and badly made.
              ( one of the things that I had to do was to strip down the gearbox completely and take about a teaspoonful of foundry sand our that had been left there.
              regarrdes fred
              #98666
                Fred … that's much easier name.
                O.K. that sounds like a good plan.
                It would be worth looking at the components available from Marchant Dice.
                [they also trade on ebay, so you might find a bargain]
                Provided that you keep a realistic balance between the "weight" of the machine, and the loads you expect to put on it; the only real problem will keeping the dust and swarf out of the linear bearings.
                Good luck … and please keep us informed of progress.
