Limp Probe Denouement
Home Forums Workshop Techniques Limp Probe Denouement
  • #16297
    martyn nutland
      @martynnutland79495
      Solution
      martyn nutland
        @martynnutland79495
        Hello Everyone
        I thought those of you who so helpfully contributed to the thread on the dangly probe on my new coaxial indicator might be interested in the denouement.
        Jason thought, and I had also come to the view, that the reason it didn't work was a lack of resistance between the slot in the beam and the arm that holds the probe. He suggested the simple expedient of devising a way of increasing the pressure on the clamping screw. But of course, by then I had broken the arm!
        So I milled and drilled a thicker replacement arm to create more friction in the slot. I had difficulty machining the 48° wedge shape (cam?) on either side that bears on the slope of the beam and my version is a lot less elegant than the original. But it does work and is made from good steel instead of some kind of 'monkey metal'.
        I tested it at 100 rpm on the inside diameter of an Austin Seven piston skirt and got the needle on the indicator dial to quiver around 0.01mm of zero. I don't think I can do much better than that other than send for a Blake!
        Bonne Weekend Martyn
        #554347
        Howard Lewis
          @howardlewis46836
          Thanks form the feedback.
          Hopefully, all will now be well!
          #554357
          Clive Foster
            @clivefoster55965
            Martyn
            Great to hear that its sorted and giving you good results.
            That's about as good as I get on any normal object. Need something that has had serious efforts to produce a good finish and accurate roundness to get the twitch significantly less.
            Never seen absolute rock steady zero twitch but I have seen barely visible movement.
            They may not be a perfect device but they are darn good by any realistic standards. Most especially so considering the modest price.
