I will probably be using my Tom Tom in two weeks’ time so it will be interesting to see how “she” and I get on, in the light of the above discussion.
Luckily I could still find my destination by maps and memory although not very easily. I did up-date it a few months ago and don’t recollect too much difficulty, other than from MS WIN-11 trying to deny the outside electronic world exists, but I may try plugging it in to the PC and see what happens…
The more serious difficulty is that by very infrequent use its internal battery runs so flat it needs a couple of hundred miles to recharge and for the instrument to start. Probably worth me using it once every couple of weeks or so even on regular journeys, just to keep it charged. And to give the lady in the box a little exercise.
It is though a right so-and-so to use. Entering a new destination, which you’d imagine should be quick and simple, is the most awkward task going. It has no equivalent of “Enter”, and its programmer seems to think you only ever enter such information just as you set off. For you have to remember that at some point you select “Drive”, assuming you have remembered the correct sequence to reach that appearing on the screen. Make a mistake and you have to start all over again.
