Posted by Alan Wood 4 on 07/10/2016 10:06:46:
Now you mention it, the problem mechanisms were the ones with the two pins to short on the back to manually set the time.
I can't recall visiting a Lidl in UK but when in France we do buy quite a bit there. My other half does the food and I go rummaging in their 'specials' bins. I picked up a really good socket and spanner set for EUR80 and have had a cheap digital caliper and inside/outside thermostat. Sometimes you win and sometimes you lose but either way the prices seem very low given the X/F.
Alan
Don't you mean the aisles that keep having things in them that you didn't know you wanted ? ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
The last one for me was a mini compressor for the car tyres. Much longer lead than the one I have. The one before that was an electric chain saw on the end of a long pole. All of our frying pans are from Lidl. Way better than what most shops stock but the best one is too heavy for my wife. I usually use it for curries and stuff like that.
The 2 pins are for resetting it to the 12 o'clock initial hands position mode. The wiki reckons that the signal is greater than 100uV / m all over the UK. Not exactly weak and is used in some areas of France. The German transmitter is way more powerful but some of it's coverage depends on ionospheric hop which can be a bit mixed. It's incredibly powerful in Germany but I can't find figures for any where else. This what they say about it
2. In the distance range between approx. 600 and 1100 km, ground and sky wave may occasionally be of equal size which may lead to mutual fading when both signals are out of phase. On the other hand, equal phase may also lead to a strong temporary increase in the field strength. Both phenomena are also observed in Braunschweig (d = 273 km). In this context it is important to know that this "beat" between ground and sky wave is a slow process (it takes a quarter of an hour and longer) and that there is thus sufficient time for a radio-controlled clock to take up the DCF77 time information.
3. At distances of more than 1100 km, the ground wave fraction constantly decreases, and the sky wave, whose propagation at large distances is fairly constant especially during the day, prevails. At distances between 1100 and 2000 km, field strengths of the sky wave between a few hundred and approx. 100 µV/m are to be expected.
I'd say with the UK one it would very definitely be ground wave. Maybe this is why they dropped the power after switching from the Rugby transmitter. RF propagation can be really weird.
Adding another interesting aspect my son forked out for a radio controlled wrist watch. It should change time where ever he goes – it would if the standards were all the same so hasn't.
Edited By Ajohnw on 07/10/2016 16:36:16
