Lidl plasma cutter
Lidl plasma cutter
Home Forums Workshop Tools and Tooling Lidl plasma cutter
  • #716561
    Stuart Smith 5
      @stuartsmith5
      Lidl have a plasma cutter in at least some stores at £140.
      It has a built in compressor or can be used with an external one.
      Bought one but not tried it yet.
      Stuart
      Chris Crew
        @chriscrew66644
        It seems to have gone up in price since the last batch, but I don’t think the last one had a built-in compressor. There was some controversy, IIRC, about its suitability for use on a domestic supply (it was supplied without a 13amp plug fitted to circumvent regulations) but I have used a similarly supplied stick welder on the workshop ring without issue. Whether this has caused issues for the neighbours or the electricity supplier I don’t know because nobody has said anything (yet!).
        #716659
        Stuart Smith 5
          @stuartsmith5
          It has a blue 16A plug fitted. There are some contradictory statements in the manual though. One is ‘ This plasma cutter with compressor is not suitable for commercial use. Commercial use will invalidate the warranty’ . The other is ‘According to the standard IEC 60974-10, this is a plasma cutter in electromagnetic compatibility Class A. Class A devices are intended for use in an industrial environment.’
          Stuart
          #716669
          Dave Halford
            @davehalford22513
            First meaning it won’t stand up to constant use.
            Second meaning as it stands it’s electrically an noisy pig where it won’t have industrial noise suppression.
