Try Frank E Marlow's Machine Shop Essentials. Chapter 8 covers milling, and is Bridgeport centric.
The book is American, fairly modern, well-written, with lots of pictures!
My workshop is too small for a Bridgeport so I'm used to a much less rigid Chinese machine. All mills work in much the same way, allowing work clamped to a table to be moved X,Y relative to a cutter. In some machines Z movement is provided by a quill moving the tool, a more rigid solution is the lift the whole table.
Bridgeports are desirable because they're moderately rigid and come with lots of reliable features – versatile, general purpose and aimed at small professional workshops. Not much to criticise. Biggest risk with them, I think, is a tendency for owners to assume sheer size, weight and power mean they can maintain accuracy whilst taking seriously heavy cuts. They're good, but not that good.
Not the Bridgeport's fault, but perhaps they encourage overconfidence. It's more obvious that smaller mills have limitations, but all machines have a sweet spot, and part of the learning process is finding it. Don't panic, it's fairly broad.
Two common beginner mistakes are either going in too hard or pussyfooting. I was a pussyfooter, until this forum put me right (thanks Andrew). The problem with taking very light cuts is it quickly blunts the cutter for very little in return. Results worsen until the learner evenetually realises the cutter is blunt, and then – because he only tool light cuts – he's convinced the cutter must be cheap rubbish. Possibly it was, but beware; light cuts quickly destroy sharp edges on good tools.
What's needed is a cut of decent depth coupled with about the right feed-rate, with a sharp tool spinning at about the right RPM. Getting the combination right optimises finish, metal removal rate and accuracy. Taking light cuts with a blunt cutter is bad news, and so is a vicious assault that strains the motor and drive train, flexes the machine's frame, bends the cutter, and overstresses the sharp edge. I start with rule of thumb settings:
- rpm = 10000 / cutter diameter in millimetres. This is about right for HSS and mild-steel. Apply a multiplier for the material, for example half for cast-iron, x5 for Aluminium, x2 for Brass. If the cutter is carbide, multiply the above again by 2 or more.
- depth of cut 5 to 20% of cutter diameter, I go for a little over 10%, or an eighth because the mental arithmetic is easy
- feed rate by ear and eye. The finish should be reasonable, and I like to hear the motor and drive train sound loaded to about 20% short of complaining! i.e not straining or idling.
May be necessary to experiment with all three, but usually tweaking the feed rate is enough.
Practice, and avoid unknown scrap. Buy known metal where the spec has words like 'free cutting', or 'good machinability'. Many alloys are not easy to machine, and some are impossible! Pussyfooting with a lump of work-hardening stainless steel is heart-breaking.
