Posted by Paul Kemp on 13/06/2018 01:29:05:
Terry,
Duncan's advise is sound re getting a club boiler inspector involved and as Paul asks you really need to give more detailed information to get an informed reply. Is the leak at the firebox end or the smokebox end, how bad is it? Can you maintain the test pressure on a pump with just a weep or is it streaming out and you can't hold the pressure at all?
To give you some info assuming it is a copper boiler which is silver soldered sadly it is not usually possible to make any long lasting repair if the leak is where it is likely to be which is the soldered joint of the tube to tube plate. Some will claim it is possible but if the boiler has ever been steamed there will be scale / corrosion or even products of combustion in the interface between tube and plate which is impossible to properly clean and get a proper full penetration solder joint. In addition getting the heat to the joint will undoubtably disturb adjacent tubes and like as not cause more leaks! It may be possible if it's silver soldered to clean around the joint and run a fillet of high temp soft solder (comsol) round it to get a seal that may last a few seasons.
That said, how bad is the leak, is it just a bead of water, a slow drip or a steady stream? Depending on how bad the leak is and having a pragmatic and informed boiler inspector if it's just a bead it may still pass a hydraulic test. On a risk basis if the joint lets go altogether what is the worst that can happen? It will put the fire out, may send a jet of steam out the firehole door or up the chimney but it's very unlikely to lead to a full blown spectacular catastrophic failure! I have a copper loco boiler that has a slight weep from a top tube in the firebox on a cold hydraulic test but when hot it seals and there is not a whisp of steam, it's been like it many years and has never got any worse. So before doing anything get it looked at by an experienced inspector. If it's just a pin hole in the silver solder it may be possible to peen it over to seal it. Better to look at the easy, cold options first before trying to wade in with a blow lamp! Another dodge if it's a pin hole is to steam it up using water in which you have boiled potatoes, the starch in the water will be carried into the hole and if you are lucky seal it! No doubt there will be people who will hysterically react to these 'bodges' but these will be the people who have little or no experience or have never witnessed a full size boiler hydraulic test.
Worst case scenario if it's a decent leak and the joint has completely failed is a new boiler. From your other posts I deduce that you have bought this engine without any assistance or advice from someone with some experience and are now sadly reaping the benefits of not knowing the pitfalls. Buying a steam engine without any certification is a lottery unfortunately.
Paul.
Hi Paul, I got the pressure up to 40 psi and the water started a fast drip from the firebox end. No ,it doesnt hold the pressure. I bought this after being told it was steamed a couple of times in the past and was just an ornament now? I wasnt to worried about certificate because I didnt intend to use it in a public place, just for my own safety.
I contacted four clubs up to around fifty miles away, one was quite near, running locos every Sunday for the public to ride on etc and I asked who inspected their boilers and would they do mine at whatever cost and they said they dont know anyone who could do it?? Only one other bothered to even reply and Im not sure they even do live steam?
I have no problem stripping it and sending the boiler away to repaired or whatever,its finding someone who could do the work?
The boiler looks like brass?
thanks all for your help
