Leak from pressure pump/nut
Home Forums Beginners questions Leak from pressure pump/nut
  • This topic has 18 replies, 9 voices, and was last updated 2 May 2023 at 21:33 by Nigel Graham 2.
  • #642999
    Mash Anscombe
      @mashanscombe79638
      Hi there, I am new to this so forgive if needed. I am restoring an old blow torch, well 2 in to 1 and mostly going well, I have it burning now, but I have a leak coming from the pump nut area. There is no washer there but I don't think there should be? Someone I know said, just from a video I sent them, that the safety valve isn't working? The pressure release valve certainly works. Please advise, I am trying to sort this as a gift to my son as he wants to get a new canal boat with a Bolinder engine and a blow torch is how you get them started . Thank in advance for any suggestions offered.
      Mash Anscombe
        @mashanscombe79638
        Leak from pressure pump area on paraffin blow torch
        #643047
        Dave Halford
          @davehalford22513
          They meant the pump non return valve
          #643050
          Mash Anscombe
            @mashanscombe79638
            Ah, thanks, that makes sense. So I need a new washer bit in there? What would I make this from please or can I acquire one from somewhere?
            #643051
            Dave Halford
              @davehalford22513
              Take the pump unit out and see.
              #643052
              Mash Anscombe
                @mashanscombe79638
                It looks a little less than good, what alternative could I use please?
                #643060
                Nick Hughes
                  @nickhughes97026
                  Give Base-Camp a call or e-mail, to see if they can help.
                  #643066
                  Mash Anscombe
                    @mashanscombe79638
                    Thank you, I will do that
                    #643068
                    john halfpenny
                      @johnhalfpenny52803
                      Is there a small one-way valve at the base of the pump tube?
                      #643069
                      Bo’sun
                        @bosun58570
                        Hi Mash,
                        Another vote for Base Camp.
                        #643073
                        Mash Anscombe
                          @mashanscombe79638
                          Posted by john halfpenny on 29/04/2023 12:28:13:
                          Yes, the little pip, I think this may be perished
                          #643074
                          Mash Anscombe
                            @mashanscombe79638
                            Posted by Bo'sun on 29/04/2023 12:34:28:
                            Hi Mash,
                            Thank you
                            #643478
                            Nigel Graham 2
                              @nigelgraham2
                              Base Camp was my thought too, having overhauled a 'Vapalux' paraffin-vapour lamp with parts from them.
                              A copy of the instructions too, vital as these lamps are operated in a way very different from most equivalents.
                              #643483
                              duncan webster 1
                                @duncanwebster1
                                Posted by Nigel Graham 2 on 01/05/2023 22:35:15:
                                …….. these lamps are operated in a way very different from most equivalents.
                                Go on then it looks just like a Tilley lamp, tell us more
                                #643491
                                Nigel Graham 2
                                  @nigelgraham2
                                  The ….
                                  "Lamp, High Pressure Paraffin No.1 (Vapalux – W.O. Cat. No. JA 5557),
                                  Lamp, Store, Type B Complete, A.M. Stores ref. No. 21C/2503" ,
                                  as the instruction-card says it is, so now we know,…..
                                  …. is still a pressure-lamp and it is lit and extinguished in a fairly similar way to a Tilley Lamp, with a meths cup for pre-heating. Its trap for the unwary accustomed to Tilley Lamps, is a finger-attracting control that operates what looks like a flame-regulating needle-valve in the jet.
                                  It is not. The needle is an internal jet-cleaner and should be used only as in the instructions, including never for extinguishing the lamp.
                                  They were made, by the way, by Willis & Bates Ltd, in Halifax.
                                  #643501
                                  Mash Anscombe
                                    @mashanscombe79638
                                    Interesting, thanks. I have paraffin lamps but not a Tilley, and have watched videos on operating etc, so hopefully won't get my fingers burnt in a figurative or real way.
                                    #643649
                                    Tim Stevens
                                      @timstevens64731
                                      If you are seeking advice or parts in England, you will need to be clear whether your device is a blow-lamp – intended to provide heat (which has been overtaken by eg a propane torch), or a Tilley lamp (intended to provide light). They work on the same sorts of fuel, and in very similar ways. A piston pump pressurises the fuel tank, and the heat of the flame assists with vapourising it. The term 'blow-torch' is (in my experience) applied to more modern heat devices, usually with butane or propane gas in a separate tank, and no need to pump. And I admit that a blow-lamp should – from its name – be for lighting. But no. English is like that. Just don't get me going on carbon brushes …
                                      Cheers, Tim
                                      Edited By Tim Stevens on 02/05/2023 18:19:05
                                      #643653
                                      Swarf, Mostly!
                                        @swarfmostly
                                        Tim,
                                        A quote: "Who but the English would write 'FIRE' on a bucket and then fill it with water?"
                                        Best regards,
                                        Swarf, Mostly!
                                        #643666
                                        Nigel Graham 2
                                          @nigelgraham2
                                          Well, if they didn't put water in the bucket labelled 'FIRE' it might be awkward if things go wrong around the Blow-lamp that is a lamp not for lighting, except for lighting.
                                          Three Huzzahs for eccentricity!
                                          (Well, it makes valves work…)
