Why are people worried about the lead or sulphur in steels? Yes, those are poisonous in themselves or in compounds you can absorb, so you should take sensible precautions with them; but the quantity in steel is tiny and you are not evaporating it or turning it into soluble forms. You have far more hazardous materials around your home than leaded steel or bronze.
Nigel’s comment illustrates why employers are required to do Health and Safety risk assessments and supervise work with a ‘competent person’. He’s right, but…
The risk to health of Lead, Sulphur, Cadmium. Zinc and various other nasties in a small workshop is very low. We are unlikely to do anything that releases them, and if we do, our exposure is minimal. Cutting EN1a-Pb is unlikely to release Lead, even if done on a large scale in a factory.
Welding EN1a-Pb is hazardous though! Lead boils at 1750°C, with plenty of vapour coming off at much lower temperatures. Breathing it makes people ill! A very large dose causes obvious symptoms fairly quickly, but what usually happens is Lead accumulates in the body and the consequences appear much later. Lead damages the brain, so the first clue is victims becoming stupid in later life.
Doing a risk assessment reveals what, if anything, needs to be done. In my workshop:
- no welding, so the risk is zero.
- I occasionally braze, but that’s done at a lower temperature. The risk is close to zero.
- I cut fair quantities of EN1a but cutting doesn’t release anything. With one exception, the risk is zero.
- The exception is grinding, but I rarely grind EN1a, and if I do, the quantity is small. The risk is low.
Industry is different. Scale matters:
- Several men welding EN1a-Pb on a large scale is significantly risky. Counter-measures required. Switching to unleaded EN1a or improved ventilation plus a breathing mask. Might also be worth testing blood regularly to be sure.
- Same issue and mitigations if grinding lots of EN1a-Pb.
- Large scale cutting produces lots of swarf. Not smart to dump it in landfill because it rusts away, releasing Lead into the water table. So disposal needs some care.
Two worlds, two different answers. What’s OK in a small workshop and for some large scale processes, doesn’t apply across the board.
In industry, where the damage caused by assumptions can be enormous, UK H&S requires a risk assessment and a competent person. ‘Competent person’ is a Health & Safety role, not a specific technical skill. Usually means someone with skills and experience on the job, plus training in H&S, but sometimes might just be checking operators are following company policy. H&S training covers how to assess risk and how it might be mitigated. So a fully qualified welder isn’t automatically an H&S competent person. He could become one quite easily, but only after more training, not needed unless required to take on the H&S role.
Keeping it in perspective, Model Engineering is a safe hobby#. But that doesn’t mean we can ignore H&S entirely. When my eyes are at risk, I wear safety glasses! And I never meddle with gunpowder by candle-light!
Back to Mark’s question, EN1a is always free-cutting, the leaded version being extra good. (No experience of Tellurium here!) I think he can use any free-cutting mild-steel, and the H&S risk is zero, unless he welds or grinds it in quantity.
Finally, to be pedantic, whatever Mark buys is unlikely to be EN1a. That’s a long gone specification, no-one makes it! What we get is a similar steel, like 230M07. Unless something special is going on, it doesn’t matter.
# last week, I indulged Amateur Radio by putting up a 8 metre pole at the end of the garden and stringing a wire antenna from it into the house via an insulated loop attached to the gutter. To reach the gutter, I stretched out of an open top-floor window: rather easy to fall 6 metres on to a concrete patio, especially as my muscles are wasted, concentration poor, and I get dizzy spells. Roped myself to a double bed aware that it might not control a fall sufficiently. Radio amateurs periodically die by falling off towers, roofs, and trees, or by having heavy antenna parts drop on them from a great height. Also, shocked by static electricity and electrocuted when antennas or aluminium ladders contact power cables. When valves ruled, equipment ran at voltages way above mains. Amateur Radio is far more dangerous than Model Engineering, where I don’t know of any fatalities, yet!
Not sure what the most dangerous ordinary hobby is? Horses or motorbikes maybe.
