(1) On all their early machines Tom Senior used solid whitemetal or whitemetal lined bronze feed screw nuts . Later ones had solid bronze nuts . A very few (probably wartime) had iron nuts .
You could cast white metal in the existing nut around the existing leadscrew just like it was done in the past but better would be to use a controlled engineering approach – fill the nut with whitemetal , bore out , roughly screwcut the thread on the original lead and finish with tap .
A variation of the old idea may be possible using one of the modern metal or PTFE filled high strength engineering repair materials .
(2) It is possible to do an improvised repair on a bronze nut by a cut and shut operation . Depends what your nut actually looks like but basically put some cuts in the right place and close up the threads either by squeezing together end wise or squeezing radially . Many feed screw nuts have a longitudinal or cross cut slot and screws to close up for adjustment as standard .
(3) Making an all new nut is not at all difficult but you have to screw cut the thread . You can choose to screw cut to a finish or screwcut a little undersize and finish with tap . You are not likely to have any success directly using an ACME tap to produce the entire thread form unless its very small size .
Edited By MICHAEL WILLIAMS on 21/04/2012 18:35:05
