Posted by Cornish Jack on 04/11/2020 21:23:27:
Thank you, Robert and Peter – The grinder is a Lidl branded 20v item and dismantling it (VERY tricky) shows a compact installation with a thin oblong completely sealed unit between the battery and the on/off switch. This, I assume, contains the monitor and balance functions and is (for all practical purposes) internally inaccessable. The monitor item I was considering was somewhat simpler than your item, Peter, having built-in digital voltage read-outs and (I assumed) intended to be wired directly between the battery and on/off switch to give real-time battery voltage state. The thought was to monitor this value and stop using the grinder when the indication was at an appropriate (rechargeable) level. The supplied charger has all the necessary protection circuits and is fully serviceable, as is the battery pack (at the moment). There are probably difficulties which I haven't appreciated due to lack of knowledge – hence the call for advice.
rgds
Bill
Very hard to tell what that component is without information or disassembly. Likely not a typical lithium battery protection circuit though. These are normally inside the battery pack. It could be over-current protection, over discharge protection, over temperature protection a combination or something completely different.
Does it have any markings?
How mainy wires ? all the same size?
Robert G8RPI.
