LBSC L Class Baltic Tank in 71/4″
Home Forums Locomotives LBSC L Class Baltic Tank in 71/4″
  • #48589
    Wessexman
      @wessexman
      Hi Everyone,
      I want to build a 71/4″ gauge model of the LBSC “Remembrance” Baltic Tank engine. I wondered if anyone knows of where I could obtain some good drawings. I believe that this engine has been modelled before but can only find reference to 5″ gauge.
      Any help, guidance, advice would be greatly appreciated.
      This is an absolutely superb site and thanks to all concerned in making it happen.
      Best regards
      Keith
      Wessexman
        @wessexman
        Research
        #48716
        Chris B
          @chrisb73862
          Unless someone has re-drawn the plans for 7 1/4″ then you will have to work from 5″ drawings and multiply everything by 1.45 (7.25/5).
          I have done this with Dougal from Reeves although I used a factor of 1.5 to give more “round” numbers and just adjusted the frame spacing to suit 7 1/4″ rather than 7.5″ which X1.5 gives. Then you will need to make your own patterns and have access to a foundry
          Probably not what you want to hear
          Chris…
          #48718
          Wessexman
            @wessexman
            Hi Chris,
            Thank you very much for your response.
            The pattern making and casting elements fortunately are not obstacles – being in the foundry business and having access to pretty good commercial sand and lost-wax moulding technologies in both ferrous and non-ferrous alloys.
            The scaling of drawings would not cause any hardship either but do any 5″ scale drawings exist for this model? I am a novice model engineer so maybe they do and I have missed them. If anyone knows of a 5″ or 31/4″ model of this Class and/or drawings I would most appreciative for any leads.
            Thanks and best regards
            Keith
            #48722
            Nigel Hyde
              @nigelhyde97004
              Me to i would love to build one in 5″ or 31/2 ” one day !!!!
              I have never seen a 3.5″ or a 5″ advertised though
              Nigel
              #48725
              DMB
                @dmb
                Some years ago, the late Bert Perryman, member Worthing and Brighton & Hove clubs, built a 5″G model of “Remembrance” to works drawings and I remember seeing it running. It had the correct plates which read something like, “In memory of all the fallen LB&SCR employees in the Great War, 1914-1918.” Dont know what happened to drawings but not in Worthing club`s Library as I`m their Librarian. I believe engine accepted by York Transport Museum, so you could try them to see if you can view it.
                #48728
                Wessexman
                  @wessexman
                  Thanks vey much for your responses.
                  I have just checked with the ME magazine reference list and have found 6 references in our esteemed magazine. They are given below. I wondered if anyone could elaborate on any of these references. They include one on the 5″ gauge model by A.C. Perryman, mentioned by John Coleman.
                  Keith
                  Volume Issue Page Category Title Author
                  122 3054 90 Postbag Remembrance G.Goldring
                  141 3507 175 Exhibition Model Engineer Exhibition 1975.
                  Locomotives Class A
                  Peter Dupen
                  141 3511 411 Postbag Remembrance L.C.V.New
                  165 3879 232 On Shed (continued) Locomotive Cabs Martin Evans
                  165 3885 588 Smoke Rings Remembrance – a Model Sought Editor
                  180 4061 203 On Shed The London Brighton & South
                  Coast Railway
                  Martin Evans
                Home Forums Locomotives Topics
