Posted by Roy Birch on 25/10/2021 12:06:07:
I am going to change to working springs and dispense with the castings, does anyone know where I can get the steel to make the working springs?
Reeves2000 and Blackgates both list spring steel as no doubt other suppliers do.
While the drawing suggests 26g spring steel strip the write up says spring steel 'as used in gramophone motors' with no indication of size.
While I have read that LBSC was building a Virginia at the time of his death he had not done so at the time the design was published so I should try to contact someone who has made the working leaf springs to see whether the thickness on the drawing works. Certainly the description of 'three or four laminations per leaf' suggests some experimentation might be necessary!
Other methods include slotting out the spring steel and using tufnol instead of steel.
