A quick update on what I,ve found with my new mini lathe.
There is no evidence of any damage and all parts seem to be present except there is no manual. I,ve printed a copy off from the suppliers website but it looks years old and judging by the images in the manual the latest version lathe seems to have moved on a fair bit. Also you cant really call it a manual it contains the bare minimum and leaves a lot to be desired, so you have to work a lot out for yourself. I do have a copy of Neils book on the mini lathe which is excellent for the beginner, I would recommend it.
Everything on the lathe works as it should and I have found most of the parts to be well adjusted.
The cross slide and top slide have no play or side to side float in them and both are very smooth to operate. The cross slide has 3 thou of backlash and the top slide has 5 thou. The tailstock is very smooth but needs centre adjusting, I,ve only checked it by eye at the moment but the vertical looks spot on but the horizontal looks to be around 10-15 thou off centre.
I suspect the saddle is well adjusted but the the apron handwheel could be smoother. Its as if you can feel the rack through the handle which makes it feel lumpy, I,m hoping this can be adjusted.
The 3 jaw chuck is a bit stiffer than I would like and was wondering if I maintain the jaw 1-2-3 sequence but move them around 120 degrees to the other two positions if it would help…maybe not.
I am waiting for a dial gauge with magnetic stand so have not checked the run out on the chuck as yet.
So this is what I,ve found so far, but overall I am really pleased it seems to have been quite well setup at the factory.
Ron
Edited By Ron Laden on 21/06/2018 09:25:09
