Robin;
For a number of years I was 99% carbide tooling. Great for cast iron, but on other metals, so-so. Maybe the expensive ones I was using are not tuned to the metal turned.
I'm finishing a Worden grinder, and expect to go back to 99% HSS, but we'll see.
Yes, blue steel chips from Carbide are great, unless you are moving the carriage by hand, then your wife/husband wonders what disease you have because your hands and arms are covered in little red spots. (not joking – hot swarf causes little burns).
The Worden will also re-sharpen end-mills, and drills, so I expect it to pay for itself in saved carbide insert costs and endmill replacement fairly quickly.
Everything has its place, and for me, my choices will most likely be different from yours;
Another JohnS.
