Posted by Brian John on 19/06/2019 01:49:58:
Why do so many lathes (like mine) have speed dials that go up to 2000 RPM or 3000 RPM ? When would you ever use such high speeds ?
Two main reasons, carbide and small diameter work.
A metric rule of thumb for HSS cutting speed in mild-steel is 10000 / diameter in mm.
The most common need for high-speed on my lathe is drilling. Applying the formula suggests:
1000 rpm for a 10mm drill,
2500 rpm for a 4mm drill,
5000 rpm for a 2mm drill,
10000 rpm for a 1mm drill,
20000 rpm for a 0.5mm drill
Not essential to cut at high-speeds, but the benefit of speed becomes more obvious with small drills. At high-speed they are less likely to break and stay sharp longer. Most noticeable if you need to drill a lot of small holes in something nasty like fibre-glass printed circuit boards.
Similar advantages turning small diameter work in a lathe; high rpm makes the job a bit easier.
Carbide works moderately well at ordinary HSS speeds, but it really comes into it's own worked about 5 times faster and harder than HSS can cope with. Lots of power, high rpm, high-feeds, and deep cuts. Modern CNC machine tools often run at high-speed – up to 20,000rpm or more.
For ordinary workshop use I guess most of us work below optimum speed and it doesn't matter. The best speed is the one that suits you! Pays to experiment because there isn't a simple answer – it's a compromise between the capability of the machine and its operator, the tool he's cutting with, and the size and type of material being cut. In my workshop, the size and type of material varies almost continually as I work through a build. Loads of variation compared with most commercial work. As there's rarely a formal specification, quite often I can't be bothered to change belt speed, or select the perfect cutting tool. When it matters I take much more care, including whacking up the rpm.
