So on to the next, and hopefully last issue.
In the past, I've tried the dumbell test-piece where you turn off half a thou or so off a boss near the chuck, and off another about 6" away. To ascertain bed twist:
It's never worked, becasue I've got severe chatter, and a swirl pattern on the surface of the free-end boss. Having now completely stripped the saddle and slides, converted to wide-guide, and adjusted the gibs, I tried again, expecting to have cured whatever looseness there might have been. Result: exactly the same. There's no way I can machine even half a thou off an unsupported 1" steel boss, 6" from the chuck.
So I tried 1" aluminium, and although better, still got the same issue:
chuck boss:
6" from chuck boss:
This happens on the high and medium speeds on the ML7. Life's too short to try it on the slowest (non-back-gear) speed.
Final cut was approx. 0.0005", very slow feedrate, new tool insert. Tool was set as close to the post as possible, top slide locked by the gib strip lock screws I installed.
The measured diameters were within 0.0001" (tenth of a thou) of each other, but I'm concerned that there's an inherent looseness somewhere causing this chatter. While the bar was in the chuck, I set the mag base on the front slide, and a DTI against the spindle collar, and gave it a pull – there was negligible movement, certianly no rattle or noticeable play. Any ideas?
Thanks.
