Hi again.
I set up this morning to cut an M10 x 1.0 fine thread in brass.
I set the change wheels, gear box and found the correct pick up point.
Speed was 292 rpm and the tool is the insert type I mentioned in earlier posts.
Top slide set parallel and infeed by cross slide.
Half nuts engaged at correct pick up point, cross slide backed out, manual return to start point, infeed to 0 plus new cut , and so on and so forth.
Worked perfectly and produced a thread which fits well in a tap cut nut.
Look like back to basics is the way forward.
Any thoughts on retracting tool holders?
Relieved of Barnsley
