Lathe Rear Tool Post For Parting Off
Home Forums Beginners questions Lathe Rear Tool Post For Parting Off
Viewing 2 posts - 26 through 27 (of 27 total)
  • #262519
    Ajohnw
      @ajohnw51620
      Posted by not done it yet on 22/10/2016 06:30:03:
      Possibly there is something to do with rigidity on small lathes, but in that case why not do all turning from the back with the lathe running forwards? There may be more questions than answers on this one! But if it works for you, then so be it – parting is not a large percentage of lathe work, after all.
      You can turn from the rear. Just add another toolpost and invert the tool. It's usually reserved for parting off even on lathes that don't have any problems doing it. Many things that are turned up need parting off so it saves fitting the tool.
      Howard Lewis
        @howardlewis46836
        I made myself a Four Way Rear Tool Post for my lathe (An ETR BL12/24 – a Warco BH600 or Chester Caftsman lookalike).
        The parting tool is mounted inverted, in a resilient holder, and with the lathe run, fairly slowly, in Forward, as normal.
        In nearly a dozen years of use, there have been very few jams, and the 3/32" blade has never broken. To make matters worse, it is ground at an angle to produce no "pip" on the back of the workpiece, which should invite a jam up because the swarf is wider than the groove!.
        I have even, on occasions, used a power feed of 0.0022"/rev without problems.
        A steady drip feed of soluble oil, from a bottle placed above the lathe, does help
        In contrast, a 1/16" blade, mounted solidly, in the Front Tool Post broke several times, so much so that I cannot recall when it was last used.
        The other spaces carry toolbits to produce for Front and Back chamfers.
        The Back Tool Post very rarely comes off the Cross Slide, usually to take it to exhibit at a show.
        Definitely the way to go!
