Lathe newbie in East Midlands
Home Forums Introduce Yourself – New members start here! Lathe newbie in East Midlands
  • #40787
    Cai
      @cai
      Cai
        @cai
        Hi,
        My names Cai and I bought a Myford ML7 lathe a few months ago to increase the types of work I can do when restoring old engines and classic motorcycles. I am avid amateur motorcycle mechanic with the ambition to one day fabricate my own single cylinder engine.
        I've only used my ML7 for simple tasks so far and hoping to learn much and, in time, help others out along the way!
        Diolch! / Thanks!
        #467530
        Brian H
          @brianh50089
          Hello Cai and welcome. There are quite a few motorcycle fans on here and one or more should be along soon.
          #467557
          Nigel McBurney 1
            @nigelmcburney1
            Hi I restore stationary engines and have restored a few pre 65 trials bikes, I suggest that you get to know how to use the ML 7 and begin to make a model engine and and parts for motor cycles ,you will soon find that there is a limit to the size of parts that can be made on a 3.5 inch lathe, To make a full size engine you will need a larger lathe eg 6.5 inch with gap bed ( Colchester master) or larger .I have bored the cylinder of a 4 hp Blackstone 5 inch bore 17 inches long on a Master. Phil Vincent of Vincent m/cs wrote a series of articles about 50 odd years a ago of his experiences and said that all of the Vincent crankcases were machined on a centre lathe ,he would have much preferred to use a horizontal borer, but in the years around 1948 to the mid fifties the aircraft industry had first call on machine tools partly due to the Korean war and cold war,other industries had to make do ,in those days even a new capstan lathe had 3 year waiting list.
            #467586
            David George 1
              @davidgeorge1
              Hi Cai welcome to the forum. There are quite a lot of vintage motorcyclists on here. I had a Triumph T100 Daytona, and raced with Dresda motorcycles on a Suzuki and worked in their factory. As you are in the East Midlands are you anywhere near Sutton in Ashfield where live as when thjs lockdown ends you can share problems localy as well.
              David
              Edited By David George 1 on 28/04/2020 10:57:28
              #467587
              Journeyman
                @journeyman
                Posted by David George 1 on 28/04/2020 10:56:58:
                … There are quite a lot of vintage motorcyclists on here. …
                David
                Is that motorcyclists with vintage bikes or really old motorcyclists? I guess on this forum possibly bothwink
                Edited By Journeyman on 28/04/2020 11:06:48
                #467604
                Howard Lewis
                  @howardlewis46836
                  Welcome!
                  Lots of help and advice available on here, covering all sorts of questions.
                  If you need face to face advice / help / demonstration, find a local Model Engineering Club.
                  Sometimes, you will be amazed at the wheezes that are used to solve a particular problem!
                  Whereabouts are you located in the East Midlands?. You may find like minds nearby.
                  #467616
                  Cai
                    @cai
                    Great to hear that there are plenty of classic motorcycle and engine work going on. Thanks for the heads up Nigel, yeah I think the ML7 will certainly limit some big projects I have in mind but it's a brilliant size and weight to fit into my garage. Hopefully, it won't lose much value when it comes time to upgrading to a larger lathe!
                    I'll have to do a quick google for a local Model Engineering Club to join, an excellent idea that I hadn't thought about.
                    I'm located in Loughborough for the time being
                    #467622
                    Arran Waters
                      @arranwaters20599
                      Hello Cai , welcome to the forum . I am a newbie and have a love of motorcycles , I have been making a few bits for a mates motorcycle at present and hopefully next year I plan to build a bike frame from scratch . The advice and experience on here is fantastic .
                      #468450
                        Hi Cai,
                        I sometimes wonder if this should be the motorcycle-engineer forum! You will find plenty of fellow enthusiasts here.
                        Jon Lawes
                          @jonlawes51698
                          Welcome!
